I do not think that is the reason. I have not set default options for the channel types in Kodi binding and it is working.
I can remember there is an open issue in Paper UI if you manually create Things which are related to a Bridge. The resulting UID is different than in textual configuration. Unfortunately I cannot find the source where I read it.
Did you try to put your item in a Sitemap for a different UI? Maybe Basic UI?
@Confused I looked into your code too. The implementation for the dynamic states looks good. Same comment:
The originalStateDescription paremeter of the getStateDescription could be null which should be handled in your code before accessing it’s methods.
Your binding is a new one? Do you think about providing it to the community and contribute it to the official openHAB 2 Add-ons repository? Would be very much appreciated.
I did all my thing and item setups through PaperUI. I also tried to set the item to enforce auto update (since the ones that are called have this option enabled too) but still no progress…
UPDATE: So I had time to work on it again and instead of trying to solve the mystery I added 2 more channels to the dynamic descriptor. I don´t know why and how but one of them actually worked (and I did nothing different). The code in my repository was updated. The channel that actually works is the swing mode.
Another thing I noticed: I added default options for those channels that are not working with the dynamic descriptior in the thing-types.xml. Those options also don´t appear. Any ideas?
Alright I´m already thinking this system is trying to mock me or something… I removed everything as a test and recreated it. Now the one channel that was working also stopped to work… Even state options defined in thing-types.xml are ignored… This bevaviour is so random that I´m starting to thing that there´s something wrong with the actual framework.
