After several trial and errors I figured out how to correctly implement the suggestions. Let me write it down here for future reference for those who will happen to come to this thread.
A note of warning: while randomly adding an --f7-button-height in a wrong section, it turned out that the whole ui was not operational anymore. I had to stop openhab and remove the line added from the jsondb/uicomponents_ui_page.json.
Hi all, this long-tap feature looks amazing. I am currently trying to build my own widget and merge this one with a simple-toggle I am using in several use-cases already with a HomeKit-like look:
Those are based on an f7-card. Unfortunately I couldn’t make the above work with an f7-card (background does not work properly). On the other hand the oh-cell seems to be limited in regards to default slots that are shown. When using the below code it looks good initially, but does not take the default slots into account at all and the Cell has no text or icons, while the background slot still works. Does anyone have a clue why this is the case?
The oh-cell is based on the f7-card but, as with al of the oh- type components, it’s been highly modified to be usable in a “low code”. This means that the configurations are completely different. To see how this might work with the f7-card you can check out the f7 docs:
With the oh-cell the default slot has been reconfigured to place components only on the area of the card that becomes visible when you expand the card.
Thanks for the swift reply, that’s what I thought.
I ended up not using an f7-card, but the oh-button directly.
I guess it matches the requirements of the above as well, but without having a cell and a button in the background. Short and long tap are working quite well:
