I just started to use Alexa in combination with OH3 and it works nice I was expecting some latency issues, but it works nearly instantaneously.
I was wondering if there is a way (maybe via some work around) to specify a command which does not use on or off.
Suppose I have a rule, which when triggered instructs the vacuum cleaner to clean the room. Ideally the command would be something like: âAlexa clean the roomâ and not âAlexa clean the room onâ
One possibility is to define a routine in the Alexa app on your smartphone. You can define any sentence and a related action that is to be executed.
See Amazon.com Help
