Is this bug with Items with using QuantityTypes in calculations?
Hi, i tryed to calculate temperature of my heating system, but got strange results.
If i use items with QuantityTypes in items definition “:Temperature” - the results of calculation is wrong.
Here is log with QuantityTypes - roomGoalRadT = -3227.88 - WRONG:
items:
Number:Temperature  roomSens_RadTemp        "Radiator [%.1f %unit%]"
Number:Temperature  roomSens_InWallTemp     "Room [%.1f %unit%]"
Number:Temperature  sysSens_OutTemp         "OutTemp [%.1f %unit%]"
rules:
roomT = roomSens_InWallTemp.state as Number
tempOut = sysSens_OutTemp.state as Number
roomRadT = roomSens_RadTemp.state as Number
roomGoalRadT = 32 + (roomGoalT - tempOut) + (roomGoalT - roomT) * 11
2020-04-06 22:02:30.699 [INFO ] [arthome.model.script.   ---> Heating] - Baxi
2020-04-06 22:02:30.701 [INFO ] [arthome.model.script.   ---> Heating] - roomGoalT=24
2020-04-06 22:02:30.701 [INFO ] [arthome.model.script.   ---> Heating] - gist=0.1
2020-04-06 22:02:30.702 [INFO ] [arthome.model.script.   ---> Heating] - tempOut=11.03 °C
2020-04-06 22:02:30.703 [INFO ] [arthome.model.script.   ---> Heating] - roomRadT=21.93 °C
2020-04-06 22:02:30.705 [INFO ] [arthome.model.script.   ---> Heating] - roomGoalRadT=-3227.88
Here is log without QuantityTypes - roomGoalRadT = 56 - OK:
items:
Number  roomSens_RadTemp        "Radiator [%.1f]"
Number  roomSens_InWallTemp     "Room [%.1f ]"
Number  sysSens_OutTemp         "OutTemp [%.1f]"
rules:
2020-04-06 22:03:30.582 [INFO ] [arthome.model.script.   ---> Heating] - Baxi
2020-04-06 22:03:30.583 [INFO ] [arthome.model.script.   ---> Heating] - roomGoalT=24
2020-04-06 22:03:30.584 [INFO ] [arthome.model.script.   ---> Heating] - gist=0.1
2020-04-06 22:03:30.585 [INFO ] [arthome.model.script.   ---> Heating] - tempOut=11
2020-04-06 22:03:30.587 [INFO ] [arthome.model.script.   ---> Heating] - roomRadT=22
2020-04-06 22:03:30.589 [INFO ] [arthome.model.script.   ---> Heating] - roomGoalRadT=56
I know when comparing a value to an item with a %unit% I had to do it like so.
MBR_Lum.state < 30 | " %"
Maybe it is similar for calculations.
Well, as roomGoalT isn’t of type QuantityType, your calculation is not allowed. Either change roomGoalT to be of Type QuantityType or cut the unit and recharge after calculation.
roomT = (roomSens_InWallTemp.state as Number).floatValue
tempOut = (sysSens_OutTemp.state as Number).floatValue
roomRadT = (roomSens_RadTemp.state as Number).floatValue
roomGoalRadT = (32 + (roomGoalT - tempOut) + (roomGoalT - roomT) * 11) | °C
Yes, you right, problem is in variables types. All variables must be same type.
Thank you @Udo_Hartmann
