I’m thinking of getting Ismacontrolli’s IO module iSMA-B-MIX18-IP which has Modbus tcpip but the datasheet says that the module is a master so I’m now somewhat confused whether this module would work with OH3’s Modbus binding. All my Modbus units are slaves and they work nicely with OH3.
I guess you might get faster start wit BACnet binding than Modbus. For module itself - it seems to act as Modbus TCP to RTU gateway. So you module is TCP slave and RTU master at the same time. This means that you. Looking closer at sheet I read:
Modbus Gateway: IP/RS485 (works only as a master on RS485 network).
As far I know iSMA you probably need vendor software to configure it.
@splatch, great many thanks for the info. It seems that I didn’t read the datasheet carefully enough. If I get the unit I’ll stick perhaps with Mobus because I’m more used to it but perhaps I should have a look at BACnet as well.
