Java Runtime Environment: which java platform is used and what version
openHAB version:
I know this must be a completely newbie question. I’ve checked my PC firewall on linux. I’m on the same vlan and subnet of my ubiquiti switch. I cannot access openhab:8080 or ip:8080. I ran zenmap and it indicates the port is filtered. I’ve tried other Pi’s with RuneAudio or even just ssh… I keep running into the ports being filtered. What am I missing?
Thank you for the feedback. I’m one of those people running an “advanced” network in my home - not the typical flat layout (e.g. 7 VLANS - with respective ACLs) . I’ve switched to a spare switch/router and am not having issues. I’ll have to investigate my primary network later…
In any case, thank you for the tip. I will add netstat to my tool belt.
