I had no trouble setting up OH 2.4 as docker image on a Synology Diskstation. Was building up my setup and probably restarted the server often. All seemed fine back then. But since I stopped messing around and just have openHab running it eats RAM on the box like crazy (imho).
I run
- openhab/openhab:2.4.0-alpine
- on a DS918 with 12GB RAM, 2GB swap (automatically assigned by system)
- addons, conf, userdata on volume outside the docker container
What is it doing?
- polling data via http binding from three sources and using rrd4j persistence with the updateInterval=60000
- reading some items via fritzboxtr064 binding, refresh=60000, no persistence
- showing that data as text/charts/switches in a simple sitemap in the BasicUI
Right now, according to the Docker UI on the Diskstation, the container is running for 10 days and uses 3.3GB Memory.
top reports
PID USER PR NI VIRT RES %CPU %MEM TIME+ S COMMAND 29810 100 20 0 4968.0m 3.231g 0.0 28.0 461:50.00 S /usr/lib/jvm/java-1.8-openjdk/bin/java -Dopenhab.home=/openhab ....
It is not the only container running on that box but by far the memory hog above all. And it seems to grow continuously
Any way to tame that beast - besides regular restarts?
regards
