My system environment is:
Raspbian GNU/Linux 8 (jessie)
Kernel = Linux 4.9.35-v7+
Platform = Raspberry Pi 2 Model B Rev 1.1
openHAB 2.5.4-1 (Release Build)
and I have an issue with garage door timer and notification send from a rule after 15 minutes. This message will be send only once not every time when the garage door has been opend. Any idear?
Thank in advanced.
best regads
Timo
var Timer offTimer = null
rule "Benachrichtigung_2" // 15 Minuten nach öffnen des Tores
Item Sensor_Garagentor received update OPEN
//Item Test_Gar_Sen received update ON
logInfo("Hinweise", "Sensor Garagentor ist: " + Sensor_Garagentor.state.toString )
if(offTimer === null || offTimer.hasTerminated) {
offTimer = createTimer(now.plusMinutes(15), [|
offTimer = null
if (Sensor_Garagentor.state == OPEN){
val telegramAction = getActions("telegram","telegram:telegramBot:89b7b984")
telegramAction.sendTelegramQuery("Das Garagentor steht noch auf. Soll das Tor jetzt geschlossen werden?", "Reply_Garagentor", "Ja", "Nein")
rule "Reset Benachrichtigung_2"
Item Sensor_Garagentor received update CLOSED
offTimer.cancel()
telegramAction.sendTelegram("Das Garagentor wurde geschlossen.")
rule "Reply handler for Garagentor"
Item telegramReplyId received update Reply_Garagentor
if (telegramMessage.state.toString == "Ja")
Garagentor.sendCommand(ON)
telegramAction.sendTelegramAnswer(telegramReplyId.state.toString, "Ok, das Garagentor wird geschlossen.")
else
telegramAction.sendTelegramAnswer(telegramReplyId.state.toString, "Ok, das Garagentor bleibt offen.")
Create a global variable and initialize it to yesterday (now.minusDays(1)).
in the rules that send the telegram, check the timestamp and only send a message if it’s been more than a day since the timestamp. Reset the timestamp to now when you do send the telegram.
This will only send the message once a day.
For those using Python rules, I’ve released a library you can use to do this at https://github.com/rkoshak/openhab-rules-helper. Install the rate_limit library and you can do this with one function call:
from communite.rate_limit import RateLimit
latch = RateLimit()
# From a Rule, call the latch to limit how often the a command can be sent.
# Let's say we don't want an alert more than once per hour. Any subsequent
# calls to this latch will be dropped until an hour has passed.
latch.run(lambda: events.sendCommand("Alert", "Somethings wrong!"), hours=1)
Please be aware that offTimer.hasTerminated will never be true. This condition is only true if the timer has run its code. The timer code first deletes the pointer offTimer, so this will never be true.
Your rule "Reset Benachtiigung2" cancels the timer, but does not delete offTimer, so the condition is not met after this rule was executed.
It’s better to use changed instead of received update, because you want to trigger to the change, not the update.
So, the rules would be better something like this:
Item Sensor_Garagentor changed
logInfo("Hinweise", "Sensor Garagentor ist: {}",newState)
offTimer?.cancel
if(newState == OPEN) {
logInfo("Hinweise", "Sensor Garagentor ist: {}", Sensor_Garagentor.state)
} else {
if (telegramMessage.state.toString == "Ja") {
} else {
