it’s me again
I am getting kind of frustrated by setting up the homematic ip thermostates over my CCU3.
The problem I have, is the following:
I did setup some rules to control the thermostates by time.
Everythings works as it should be, but then I found out (when I was standing in a cold bathroom in the morning) that the thermostat is being set back to the temp. which was set by me once over hardware-buttons it self.
Now I tracked it down to the following: when I set the temp 17degrees on the thermostat by using the hardware buttons and later on, set the temp by a rule to 20degrees, the temp is set back 17degrees after 14 to 58min.
Now what I have tried:
- I made sure, that there is no configuration on the CCU3
- That the MANU_MODE is active
- No other rule is setting the temp by mistake (which would be strange because of the different time it happens)
I have also played with the settings in the configuration-tab in the PaperUI. There you can change, who can control the temp in MANU_MODE. When I use “SET_TEMPERATURE_CHANGE_ONLY_BY_NONE” and “ONLY_BY_SELF”, it obviously is not changed by the rule. In the event.log I see that is is changed but since the device does not alow it, the temp on the device stays as is. So when I use “ONLY_BY_RT_TC_SC_SELF” or “BY_ALL” the problem from above happens.
I will set it to “ONLY_BY_CCU” now and see if this works (I’m at work atm, so I can not check the device (only the logs)). I will post an update here if this shows any different result.
But for now, maybe someone already had this issue with the Homematic-Ip devices and the Homematic CCU3 and can tell me what I did wrong when configuring the connection.
(Btw.: the CCU3 is configured via things-file but the thermostats are added through PaperUI (cause I thight it makes a difference (which it does not )))
Update: changing to “ONLY_BY_CCU” did not change anything. I did set it by rule to 17 and after about 15minutes, it was changed to 20 by the system (or some troll who is living under my batroom-sink and keeps changing it always back to 20 )
