Hello, first time poster,
I don’t know if this is the right place here.
I have an issue with the visualstudio-Code extension: I can’t get the REST integration working.
My network config is the following:
Raspbi with Openhab :10.130.10.179
Gateway: 10.130.10.1
PC (windows) with editor 10.130.10.100
The adress it tries to connect to is the adress from my external server, the only way it can get to this ip is through weird DNS resolving stuff.
But since theres an ip, it shouldnt try to resolve something…
I’ve tried so far different host declarations (with HTTP:// and without), even a local URL with resolving in the hosts file…
has anyone an idea what’s happening here?
the next thing I would try would be digging deeper with Wireshark.
Edit:
Wireshark confirms that it is trying to connect to the external ip.
I should do more rubberduck debugging.
I figured it out: it was indeed a DNS specific problem.
At windows, theres something like a Connection specific DNS suffix in the Network configuration.
Thats normally your Domain in your network and is used if something tries to resolve an incomplete domain, like hab (instead of hab.local for example).
The extension added this suffix every time, even if only an ip was specified or a FQDN was given.
For example: if the specific suffix is mynetwork.local and the domain of the openhab system is hab.mynetwork.local, it tried to resolve hab.mynetwork.local.mynetwork.local.
but since i’ve got a domain and i use it both for external sites and internal networking (with internal things only specified in internal dns resolver) it got an external valid dns request with an sub that couldn’t internally resolved and so it got the fallback to the wildcart in the public dns zone.
I dont know if this is a general bug with resolving or how it didnt work with just the ip.
Maybe my system is simply too f*cked up.
Yeah, but for me the IP didn’t work either, because it tried to parse the ip like a domain and added the suffix.
But after i figured it out how it messes up, i was able to go around it.
