did a fresh install of centos 8 with zulu11
i installed openhab3 and configured the java options for my ember controller No communication ports found, cannot connect to [/dev/ttyUSB1]
i get the USB ports in my drop down so I do not believe the java options is an issue
The permissions for the file have the dialout group
openhab is a member of dialout group
2020-11-08 15:43:32.720 [DEBUG] [nding.zigbee.serial.ZigBeeSerialPort] - Connecting to serial port [/dev/ttyUSB0] at 57600 baud, flow control FLOWCONTROL_OUT_RTSCTS.
2020-11-08 15:43:32.723 [DEBUG] [nding.zigbee.serial.ZigBeeSerialPort] - No communication ports found, cannot connect to [/dev/ttyUSB0]
same issue tried various baud rates and hardware/software flow control
currently running
Centos 8
openJDK11
Openhab 3.0.0.M2
the dongle is a Nortek husbzb-1 which i have been using for over a year without issue on openhab2
What does dmesg | grep tty show? The OS needs to recognize the device first. For example here is mine with a zigbee & zwave stick using .dev.ttyUSB0 and /dev/ttyUSB1…
pi@raspberrypi:~ $ dmesg | grep tty
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000876] printk: console [tty1] enabled
[ 2.523364] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 7.283286] usb 1-1.1.3: cp210x converter now attached to ttyUSB0
[ 7.295514] usb 1-1.1.3: cp210x converter now attached to ttyUSB1
I am currently using that same dongle in my test system, a Raspberry Pi running the latest OH3 snapshot in Docker container. Both Zwave and Zigbee are recognized by the bindings. Perhaps something different is happening with security permissions in RedHat based distributions. You may want to try selinux in permissive mode.
Sorry - I’m not really sure why the serial ports wouldn’t work. From the binding perspective there’s no change between OH2 and OH3 and certainly in my tests here I’ve had no problems. Unfortunately I’m not really sure what else to suggest - sorry.
2020-11-21 09:28:13.785 [INFO ] [me.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:fb110aa92b' changed from UNKNOWN to OFFLINE: Failed to open communications port
Another VM with OH 2.5.10 works fine. and Z-Wave has a similar issue. This points to something serial port related within OH3 Core.
