maybe someone can give me some hints regarding 3 issues after I migrated to 4.0.1.
- /var/log/openhab/events.log stays empty, so no logging e.g. in frontail webservice
- Can’t select a channel based trigger via UI.
- Warning about my rules, after migration
Info System:
1.) log4j2.xml:
- frontail doesn’t show any events from items, so I double checked my log files and the log4j2.xml seetings. Could not find any problems there.
- Only that the events.log files stay empty, I already rebooted, clean-cache, uninstalled and reinstalled ZRAM and Frontail. But no changes here.
<?xml version="1.0" encoding="UTF-8" standalone="no"?><Configuration monitorInterval="10">
<Appenders>
<!-- Console appender not used by default (see Root logger AppenderRefs) -->
<Console name="STDOUT">
<PatternLayout pattern="%d{HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n"/>
</Console>
<!-- Rolling file appender -->
<RollingFile fileName="${sys:openhab.logdir}/openhab.log" filePattern="${sys:openhab.logdir}/openhab.log.%i.gz" name="LOGFILE">
<PatternLayout pattern="%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n"/>
<Policies>
<OnStartupTriggeringPolicy/>
<SizeBasedTriggeringPolicy size="16 MB"/>
</Policies>
<DefaultRolloverStrategy max="7"/>
</RollingFile>
<!-- Event log appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/events.log" filePattern="${sys:openhab.logdir}/events.log.%i.gz" name="EVENT">
<Policies>
</Policies>
</RollingRandomAccessFile>
<!-- Audit file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/audit.log" filePattern="${sys:openhab.logdir}/audit.log.%i.gz" name="AUDIT">
<Policies>
<SizeBasedTriggeringPolicy size="8 MB"/>
</Policies>
<!-- OSGi appender -->
<PaxOsgi filter="*" name="OSGI"/>
</Appenders>
<Loggers>
<!-- Root logger configuration -->
<Root level="WARN">
<AppenderRef ref="LOGFILE"/>
<AppenderRef ref="OSGI"/>
</Root>
<!-- Karaf Shell logger -->
<Logger level="OFF" name="org.apache.karaf.shell.support">
<AppenderRef ref="STDOUT"/>
</Logger>
<!-- Security audit logger -->
<Logger additivity="false" level="INFO" name="org.apache.karaf.jaas.modules.audit">
<AppenderRef ref="AUDIT"/>
</Logger>
<!-- openHAB specific logger configuration -->
<Logger level="INFO" name="org.openhab"/>
<Logger level="DEBUG" name="openhab.event.ItemStateEvent"/>
<Logger level="DEBUG" name="openhab.event.ItemStateUpdatedEvent"/>
<Logger level="ERROR" name="openhab.event.GroupStateUpdatedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemAddedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemChannelLinkAddedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemChannelLinkRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.ChannelDescriptionChangedEvent"/>
<Logger level="ERROR" name="openhab.event.ThingStatusInfoEvent"/>
<Logger level="ERROR" name="openhab.event.ThingAddedEvent"/>
<Logger level="ERROR" name="openhab.event.ThingUpdatedEvent"/>
<Logger level="ERROR" name="openhab.event.ThingRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.InboxUpdatedEvent"/>
<Logger level="ERROR" name="openhab.event.RuleStatusInfoEvent"/>
<Logger level="ERROR" name="openhab.event.RuleAddedEvent"/>
<Logger level="ERROR" name="openhab.event.RuleRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.StartlevelEvent"/>
<Logger level="ERROR" name="openhab.event.AddonEvent"/>
<Logger additivity="false" level="INFO" name="openhab.event">
<AppenderRef ref="EVENT"/>
</Logger>
<Logger level="ERROR" name="javax.jmdns"/>
<Logger level="ERROR" name="org.jupnp"/>
<!-- This suppresses all Maven download issues from the log when doing feature installations -->
<!-- as we are logging errors ourselves in a nicer way anyhow. -->
<Logger level="ERROR" name="org.ops4j.pax.url.mvn.internal.AetherBasedResolver"/>
<!-- Filters known issues of pax-web (issue link to be added here). -->
<!-- Can be removed once the issues are resolved in an upcoming version. -->
<Logger level="OFF" name="org.ops4j.pax.web.pax-web-runtime"/>
<!-- Filters known issues of lsp4j, see -->
<!-- https://github.com/eclipse/smarthome/issues/4639 -->
<!-- https://github.com/eclipse/smarthome/issues/4629 -->
<!-- https://github.com/eclipse/smarthome/issues/4643 -->
<Logger level="OFF" name="org.eclipse.lsp4j"/>
<!-- Filters warnings for events that could not be delivered to a disconnected client. -->
<Logger level="ERROR" name="org.apache.cxf.jaxrs.sse.SseEventSinkImpl"/>
<!-- Filters warnings from broken connections during startup -->
<!-- https://github.com/openhab/openhab-core/issues/2998 -->
<Logger level="ERROR" name="org.apache.cxf.phase.PhaseInterceptorChain"/>
<!-- Filters known issues of KarServiceImpl, see -->
<!-- https://github.com/openhab/openhab-distro/issues/519#issuecomment-351944506 -->
<Logger level="ERROR" name="org.apache.karaf.kar.internal.KarServiceImpl"/>
<!-- Filters warnings about unavailable ciphers when JCE is not installed, see -->
<!-- https://github.com/openhab/openhab-distro/issues/999 -->
<Logger level="ERROR" name="org.apache.karaf.shell.ssh.SshUtils"/>
<!-- Filters known issues of javax.mail, see -->
<!-- https://github.com/openhab/openhab-addons/issues/5530 -->
<Logger level="ERROR" name="javax.mail"/>
<!-- Filters disconnection warnings of the ChromeCast Java API, see -->
<!-- https://github.com/openhab/openhab-addons/issues/3770 -->
<Logger level="ERROR" name="su.litvak.chromecast.api.v2.Channel"/>
<!-- Added by Karaf to prevent debug logging loops, see -->
<!-- https://issues.apache.org/jira/browse/KARAF-5559 -->
<Logger level="WARN" name="org.apache.sshd"/>
</Loggers>
</Configuration>
Log levels:
Log files:
2.) No Channel:
- noticed that my items based on events from channel triggers didn’t changed, e.g. Astro Binding
- therefore I tried to create a new rule based on the channel trigger, but the channel picker popup in the UI won’t show up when I click on channel.
3.) Errors in openhab.log file,
- I installed 4.0.1 addons JS Scripting and JavaScript Scripting (Nashorn).
- I changed all non former ECMA 2021 automation scripts from application/javascript mime type to application/javascript;version=ECMAScript-5.1.
Can this be ignored?
2023-07-29 11:39:07.950 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'gAlleBatterienStatus' needed for rule 'BatterieZuNiedrig' removed. Trigger '1' will no longer work.
2023-07-29 11:39:07.962 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'SonoffSNZB03MOTION1_Bewegung' needed for rule 'EingangsflurBewegung' removed. Trigger '1' will no longer work.
2023-07-29 11:39:07.964 [WARN ] [le.handler.ItemStateConditionHandler] - Item 'gAlleBatterienStatus' needed for rule 'BatterieZuNiedrig' removed. Condition '2' will no longer work.
2023-07-29 11:39:07.990 [WARN ] [le.handler.ItemStateConditionHandler] - Item 'modeBlindsTerrasseAuto' needed for rule 'openBlindsTerrasseWeekend' removed. Condition '3' will no longer work.
2023-07-29 11:39:07.992 [WARN ] [le.handler.ItemStateConditionHandler] - Item 'modeBlindsTerrasseAuto' needed for rule 'closeBindsTerrasseWeekday' removed. Condition '3' will no longer work.
2023-07-29 11:39:07.993 [WARN ] [le.handler.ItemStateConditionHandler] - Item 'modeBlindsTerrasseAuto' needed for rule 'openBlindsTerrasseWeekday' removed. Condition '3' will no longer work.
2023-07-29 11:39:07.996 [WARN ] [le.handler.ItemStateConditionHandler] - Item 'modeBlindsTerrasseAuto' needed for rule 'closeBlindsTerrasseWeekend' removed. Condition '3' will no longer work.
2023-07-29 11:39:08.006 [WARN ] [le.handler.ItemCommandTriggerHandler] - Item 'LGOLEDTV_VolDummy' needed for rule 'VolumeUpDown' removed. Trigger '1' will no longer work.
2023-07-29 11:39:08.007 [WARN ] [le.handler.ItemStateConditionHandler] - Item 'VariableActuator_Urlaub_Status' needed for rule 'Anwesenheitssimulation_Lampen' removed. Condition '5' will no longer work.
2023-07-29 11:39:08.011 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'VariableActuator_Urlaub_Status' needed for rule 'AVM_Urlaubsschaltung_Anwenden' removed. Trigger '1' will no longer work.
2023-07-29 11:39:08.012 [WARN ] [le.handler.ItemStateConditionHandler] - Item 'VariableActuator_Urlaub_Status' needed for rule 'AVM_Urlaubsschaltung_Anwenden' removed. Condition '4' will no longer work.
2023-07-29 11:39:08.012 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'VariableActuator_Urlaub_Status' needed for rule 'AVM_Heizung_Autmatik_Vorlage' removed. Trigger '1' will no longer work.
2023-07-29 11:39:08.014 [WARN ] [le.handler.ItemCommandTriggerHandler] - Item 'VoiceCommand' needed for rule 'VoiceTest' removed. Trigger '1' will no longer work.
2023-07-29 11:39:08.059 [WARN ] [le.handler.ItemCommandTriggerHandler] - Item 'LGOLEDTV_ChannelDummy' needed for rule 'ChannelUpDown' removed. Trigger '1' will no longer work.
2023-07-29 11:39:08.082 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'HeizungWohnzimmer_SetTemp' needed for rule 'HeizungEGStatusWennTuerLangOffen' removed. Trigger '2' will no longer work.
2023-07-29 11:39:08.097 [WARN ] [le.handler.ItemStateConditionHandler] - Item 'steckdosemobil2' needed for rule 'BeleuchtungAus' removed. Condition '3' will no longer work.
2023-07-29 11:39:08.107 [WARN ] [le.handler.ItemCommandTriggerHandler] - Item 'SchlafzimmerFernseher_ChUpDown' needed for rule 'SchalfzimmerTV_Channel_UpDown' removed. Trigger '1' will no longer work.
2023-07-29 11:39:08.113 [WARN ] [le.handler.ItemStateConditionHandler] - Item 'isNight' needed for rule 'Anwesenheitssimulation_Lampen' removed. Condition '4' will no longer work.
2023-07-29 11:39:08.116 [WARN ] [le.handler.ItemStateConditionHandler] - Item 'isNight' needed for rule 'MotionTest' removed. Condition '3' will no longer work.
2023-07-29 11:39:08.173 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'Windows10_Online' needed for rule 'HeizungKellerFlurimWinter' removed. Trigger '1' will no longer work.
2023-07-29 11:39:08.175 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'Windows10_Online' needed for rule 'HeizungBueroKellerflurImSommer' removed. Trigger '1' will no longer work.
2023-07-29 11:39:08.176 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'Windows10_Online' needed for rule 'HeizungBueroimWinter' removed. Trigger '1' will no longer work.
2023-07-29 11:39:08.177 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'Windows10_Online' needed for rule 'OfficeWindowsPC_PingStatus' removed. Trigger '1' will no longer work.
2023-07-29 11:39:08.200 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'Terrassen_Tur_TurFensterstatus' needed for rule 'HeizungAusWennEGTuerAuf' removed. Trigger '2' will no longer work.
2023-07-29 11:39:08.236 [WARN ] [le.handler.ItemCommandTriggerHandler] - Item 'Windows10_ONOFF' needed for rule 'Windows10_ONOFF' removed. Trigger '0' will no longer work.
2023-07-29 11:39:08.258 [WARN ] [le.handler.ItemStateConditionHandler] - Item 'Person1Presence_Raw' needed for rule 'MotionTest' removed. Condition '4' will no longer work.
2023-07-29 11:39:08.271 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'IkeaSchalter1_Action' needed for rule 'IkeaSchalter1_Regel' removed. Trigger '1' will no longer work.
2023-07-29 11:39:08.271 [WARN ] [le.handler.ItemStateConditionHandler] - Item 'IkeaSchalter1_Action' needed for rule 'IkeaSchalter1_Regel' removed. Condition '2' will no longer work.
2023-07-29 11:39:08.275 [WARN ] [le.handler.ItemStateConditionHandler] - Item 'modeBlindsEsszimmerAuto' needed for rule 'closeBlindsEsszimmerWeekend' removed. Condition '3' will no longer work.
2023-07-29 11:39:08.277 [WARN ] [le.handler.ItemStateConditionHandler] - Item 'modeBlindsEsszimmerAuto' needed for rule 'openBlindsEsszimmerWeekday' removed. Condition '3' will no longer work.
2023-07-29 11:39:08.281 [WARN ] [le.handler.ItemStateConditionHandler] - Item 'modeBlindsEsszimmerAuto' needed for rule 'openBlindsEsszimmerWeekend' removed. Condition '3' will no longer work.
2023-07-29 11:39:08.285 [WARN ] [le.handler.ItemStateConditionHandler] - Item 'modeBlindsEsszimmerAuto' needed for rule 'closeBlindsEsszimmerWeekday' removed. Condition '3' will no longer work.
2023-07-29 11:39:08.350 [WARN ] [le.handler.ItemCommandTriggerHandler] - Item 'SchlafzimmerFernseher_RCButton' needed for rule 'Schlafzimmer_Fernseher_RCButton' removed. Trigger '1' will no longer work.
2023-07-29 11:39:08.406 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'IKEABewegungmelder1_Bewegung' needed for rule 'MotionTest' removed. Trigger '1' will no longer work.
2023-07-29 11:39:08.408 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'fboxMacJan1' needed for rule 'HeizungBueroimWinter' removed. Trigger '4' will no longer work.
2023-07-29 11:39:08.410 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'fboxMacJan1' needed for rule 'FalconSteuerung' removed. Trigger '1' will no longer work.
2023-07-29 11:39:08.411 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'fboxMacJan1' needed for rule 'HeizungKellerFlurimWinter' removed. Trigger '4' will no longer work.
2023-07-29 11:39:08.413 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'fboxMacJan1' needed for rule 'HeizungBueroKellerflurImSommer' removed. Trigger '4' will no longer work.
2023-07-29 11:39:08.497 [WARN ] [ule.handler.GroupStateTriggerHandler] - Group 'gHeizungen' needed for rule 'AVM_Urlaubsschaltung_Anwenden' removed. Trigger '6' will no longer work.
2023-07-29 11:39:08.520 [WARN ] [ule.handler.GroupStateTriggerHandler] - Group 'Debounce' needed for rule 'DebounceNew' removed. Trigger '1' will no longer work.
2023-07-29 11:39:08.538 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'HeizungEsszimmer_SetTemp' needed for rule 'HeizungEGStatusWennTuerLangOffen' removed. Trigger '3' will no longer work.
2023-07-29 11:39:08.544 [WARN ] [le.handler.ItemStateConditionHandler] - Item 'PresenceOverride' needed for rule 'AVM_Heizung_Autmatik_Vorlage' removed. Condition '7' will no longer work.
2023-07-29 11:39:08.568 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'Gartentuer_Esszimmer_Tuerstatus' needed for rule 'HeizungAusWennEGTuerAuf' removed. Trigger '3' will no longer work.
2023-07-29 11:39:08.604 [WARN ] [le.handler.ItemCommandTriggerHandler] - Item 'LGOLEDTV_RCButton' needed for rule 'LGTV_RCButton' removed. Trigger '1' will no longer work.
2023-07-29 11:39:08.607 [WARN ] [le.handler.ItemCommandTriggerHandler] - Item 'SchlafzimmerFernseher_VolDummy' needed for rule 'SchlafzimmerTV_Volume_UpDown' removed. Trigger '1' will no longer work.
2023-07-29 11:39:08.609 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'Buro_Deckenleuchte_Schalter' needed for rule 'Deckenlampe_Status' removed. Trigger '1' will no longer work.
