I updated my OH2 installation to the most recent stable version today. Needed to reboot 3 times until all was up and running again. After this, my openhab.log gets flooded with the same message over and over again. Any ideas where to start fixing ?
2020-06-26 17:36:35.039 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 19 - ignored
2020-06-26 17:36:35.092 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 16 - ignored
2020-06-26 17:36:35.145 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 17 - ignored
2020-06-26 17:36:35.195 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 17 - ignored
2020-06-26 17:36:35.247 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 17 - ignored
2020-06-26 17:36:35.300 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 16 - ignored
2020-06-26 17:36:35.350 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 17 - ignored
2020-06-26 17:36:35.402 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 17 - ignored
2020-06-26 17:36:35.456 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 19 - ignored
2020-06-26 17:36:35.507 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 16 - ignored
2020-06-26 17:36:35.558 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 17 - ignored
2020-06-26 17:36:35.609 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 17 - ignored
2020-06-26 17:36:35.661 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 17 - ignored
2020-06-26 17:36:35.712 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 16 - ignored
2020-06-26 17:36:35.765 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 17 - ignored
2020-06-26 17:36:35.814 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 17 - ignored
2020-06-26 17:36:35.868 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 18 - ignored
2020-06-26 17:36:35.917 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 17 - ignored
2020-06-26 17:36:35.969 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 17 - ignored
2020-06-26 17:36:36.021 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 17 - ignored
2020-06-26 17:36:36.074 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 17 - ignored
2020-06-26 17:36:36.127 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 19 - ignored
2020-06-26 17:36:36.178 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 17 - ignored
2020-06-26 17:36:36.230 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 19 - ignored
2020-06-26 17:36:36.284 [WARN ] [p.KNXnet/IP Routing 224.0.23.12:3671] - received frame length 0 for KNXnet/IP routing.ind (0x530 v1.0) length 17 - ignored
- Platform information:
- Hardware: RPi 3b+
- OS: openhabian environment
- Java Runtime Environment: openhabian environment
- openHAB version: 2.5.6-2
- Issue of the topic: Log getting flooded
