As I am migrating from OH1 to OH2, I am having a few issues with 2 (out of 30) ZWave devices. They show in the inbox, but they do not want to initialise. In the log I get this:
2020-05-23 18:03:41.961 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 33: Device discovery could not resolve to a thingType! Manufacturer data not known.
2020-05-23 18:03:41.966 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 39: Device discovery could not resolve to a thingType! Manufacturer data not known.
Device 39 is a Fibaro flood sensor FGFS101, exactly like another one that I have that works well—this is taken from the other one:
dbReference 392
defaultAssociations 1
manufacturerId 010F
manufacturerRef 0B00:1001,0B01:1002,0B01:1003,0B01:2002,0B01:3002
modelId FGFS101
vendor Fibargroup
versionMax 23.0
versionMin 3.2
Unfortunately, I cannot initialise device 39. I tried waking it many times, ensured battery is good, gave it a few hours, took the Gen5 stick out of the host to exclude and include manually (not in secure mode) and exclude again. In all cases the stick’s LEDs confirm successful inclusion/exclusion. I also did a factory reset of the flood sensor. I still cannot initialise or add it!
I was hoping to find some ZWave UI in either Paper UI or HABmin to full delete the device from the database and include again. I cannot find it—where is the UI for doing that in OH2?
Device 33 is a phantom leftover from a couple of years ago: a device that I had factory reset but could not remove at the time in OH1. I suspect it might be a replica of one of my other devices, perhaps even a working one, if that is at all possible. I would like to remove it from the database.
To add to my woes, whenever I tried to put the ZWave stick into exclusion mode using the Paper UI —which, by the way, is hard to find taking 7 steps to get there: Configuration/Things/ZWave Controller/Edit/Show More/Exclude Devices/Save—I get error “Conflict 409” and this gets logged:
2020-05-23 19:18:11.472 [INFO ] [st.core.internal.thing.ThingResource] - Received HTTP PUT request for update configuration at 'things/zwave:serial_zstick:controller/config' for an unmanaged thing 'zwave:serial_zstick:controller'.
I also get that error if I tried to edit the “location” property of the ZWave stick in the UI.
I also tried in HABmin, and I also get the same logged error for both actions.
I was also hoping to see a ZWave network diagram in HABmin, just as I do in OH1. Unfortunately, that screen is always blank:
If I press the Device Tools button, nothing comes up.
Is my ZWave controller in a sick state? If I reboot into OH1 I can see the network diagram, however, I still have the issue of that “phantom” device 33. At this stage I suspect 39 (the flood sensor) will be in a confused state, too.
Other than those issues the ZWave network works well and I can control all other devices. Do I need to do a factory reset on the stick and reinclude all of my devices again? Do I need to exclude them first? Because of access issues, this will not be easy. Ideally, I would like to try a software approach first, if possible.
Many thanks for any pointers…
