I am still struggling with these two Fibaro flood sensors. I had one reset and included afresh, and it worked for a day, then it would no loger reply to the NIF request, would not wake up even if triggered manually. I wanted to remove them from the controller, so I used the HABmin option, but this is what I get in the logs:
2020-05-27 10:56:38.591 [ERROR] [message.RemoveFailedNodeMessageClass] - NODE 42: Remove failed node failed as node not found
2020-05-27 10:57:17.735 [ERROR] [message.RemoveFailedNodeMessageClass] - NODE 38: Remove failed node failed as node not found
They are still showing there. Any suggestions how to proceed?
PS. I have deleted the sensor Things and I reset them again. Unfortunately, when I search for new ZWave devices, they all keep coming back, so now I have 4 phantom devices. Further, for some reason, I see Node 1 has appeared. This is strange, as it is the controller itself. Why is it finding itself as a new âUnknown deviceâ? I now have 33, 39 (which I have had for a while), 38 (just removed), 42 (which is a replica of 33 & 39), and for some reason node 1.
2020-05-27 11:21:29.243 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 1: Device discovery could not resolve to a thingType! Manufacturer data not known.
2020-05-27 11:21:29.244 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:controller:node1' to inbox.
2020-05-27 11:21:29.259 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 31: Device discovery could not resolve to a thingType! Manufacturer data not known.
2020-05-27 11:21:29.262 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 33: Device discovery could not resolve to a thingType! Manufacturer data not known.
2020-05-27 11:21:29.263 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:controller:node33' to inbox.
2020-05-27 11:21:29.268 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 39: Device discovery could not resolve to a thingType! Manufacturer data not known.
2020-05-27 11:21:29.269 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:controller:node39' to inbox.2020-05-27 11:26:50.882 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:controller:node42' to inbox.
What is happening?
