In OH 3.1.0.M3, I tried to install the snapshot Zwave jar file (timestamp 2021-04-25-03:36) from the ci platform.
I followed the instructions in OH3 Smartthings Add-on Discovery not working - #7 by Antony_Price (although this is an other binding, the same installation rules I’d expect to apply):
- I manually removed the GUI-installed zwave binding
- Copied the new .jar to the addons directory /usr/share/openhab/addons, with as far as I know correct username, group and file access bits:
-rw-r--r-- 1 openhab openhab 3.5M Apr 26 11:22 org.openhab.binding.zwave-3.1.0-SNAPSHOT.jar
- Restarted OH with systemctl
- I tried to activate the jar via only copying the jar file in the /usr/share/openhab/addons directory, and (later), also via mentioning “zwave” in addons.cfg.
But whatever I do, I keep the error message Unresolved requirement: Import-Package: org.osgi.framework; version="[1.9.0,2.0.0)":
2021-04-26 13:46:49.443 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.zwave-3.1.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.zwave [222]
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.4]
2021-04-26 13:46:52.703 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2021-04-26 13:46:52.908 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2021-04-26 13:46:53.621 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2021-04-26 13:46:57.931 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
Result is:
openhab> list -s | grep zwave
222 │ Installed │ 80 │ 3.1.0.202104250336 │ org.openhab.binding.zwave
233 │ Resolved │ 80 │ 3.1.0.M3 │ org.openhab.binding.zwave
This issue seems to be close. It gets a similair error message, but not close enough.
Any idea’s ?
