[ERROR] [.service.ConfigurableServiceResource] - Cannot get configuration for service org.eclipse.smarthome.core.i18nprovider: Permission denied
java.io.IOException: Permission denied
Second: with datapoints ONLY for RSSI and SIGNAL_STRENGTH
[WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'NEQ0861026:0#SIGNAL_STRENGTH
The Homematic problems with RSSI / SIGNAL_STRENGHT are probably caused by a new implementation of these datapoints. Generally it should be sufficient to remove the thing in Paper UI and then detect them anew and add them from the inbox. Its a bit strange that you had to clear cache and tmp.
i use the “fix permission” option in openhabian-config.
