I’m trying to move my openhab install over to Docker, but it appears you only have 2.0 in a container. Can anyone try and do a fresh run of the latest image as I just get an error:
ross@dar-docker-01:/docker/openhab$ docker run -it --name openhab --net=host -e OPENHAB_HTTP_PORT=81 openhab/openhab:amd64-online server
**SNIP**
Hit '<ctrl-d>' or type 'system:shutdown' or 'logout' to shutdown openHAB.
openhab> [Fatal Error] :1:3: The markup in the document preceding the root element must be well-formed.
Connecting to post 81 just shows nothing is running.
The logs show:
2016-07-03 08:52:59.329 [ERROR] [.glassfish.hk2.osgi-resource-locator] - FrameworkEvent ERROR - org.glassfish.hk2.osgi-resource-locator
org.osgi.framework.BundleException: Exception in org.apache.karaf.features.internal.service.FeaturesServiceImpl$3.end()
at org.eclipse.osgi.internal.framework.OSGiFrameworkHooks$CoreResolverHookFactory.handleHookException(OSGiFrameworkHooks.java:164)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.OSGiFrameworkHooks$CoreResolverHookFactory$CoreResolverHook.end(OSGiFrameworkHooks.java:340)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleResolver$ResolveProcess.resolve(ModuleResolver.java:901)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleResolver.resolveDelta(ModuleResolver.java:111)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer.resolveAndApply(ModuleContainer.java:479)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:437)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:427)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.Module.start(Module.java:416)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1498)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
2016-07-03 08:52:59.749 [ERROR] [org.eclipse.smarthome.model.script ] - [org.eclipse.smarthome.action.transformation.action(0)] Circular reference detected, getService returning null
Is this an issue with the latest build, or expected with a first pull?
