I just migrated to a new development server and am attempting to get maven (and other build tools) all setup. As a test I’m just trying to build the androidtv binding from openhab-addons. I’m getting the following error I’ve never seen before. All I’m doing is cloning from main and running “mvn clean install -DskipChecks -DskipTests -X -pl :org.openhab.binding.androidtv” so I’m assuming it should just work. Anyone know how to fix this? Thanks!
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 2.366 s
[INFO] Finished at: 2025-01-26T16:50:02Z
[ERROR] Failed to execute goal com.diffplug.spotless:spotless-maven-plugin:2.43.0:check (codestyle_check) on project org.openhab.binding.androidtv: Execution codestyle_check of goal com.diffplug.spotless:spotless-maven-plugin:2.43.0:check failed: java.io.IOException: Failed to load eclipse jdt formatter: java.lang.RuntimeException: org.tukaani.xz.XZFormatException: Input is not in the XZ format -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal com.diffplug.spotless:spotless-maven-plugin:2.43.0:check (codestyle_check) on project org.openhab.binding.androidtv: Execution codestyle_check of goal com.diffplug.spotless:spotless-maven-plugin:2.43.0:check failed: java.io.IOException: Failed to load eclipse jdt formatter: java.lang.RuntimeException: org.tukaani.xz.XZFormatException: Input is not in the XZ format
at org.apache.maven.lifecycle.internal.MojoExecutor.doExecute2 (MojoExecutor.java:375)
at org.apache.maven.lifecycle.internal.MojoExecutor.doExecute (MojoExecutor.java:351)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:215)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:171)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:163)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:117)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:81)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build (SingleThreadedBuilder.java:56)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute (LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:298)
at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:192)
at org.apache.maven.DefaultMaven.execute (DefaultMaven.java:105)
at org.apache.maven.cli.MavenCli.execute (MavenCli.java:960)
at org.apache.maven.cli.MavenCli.doMain (MavenCli.java:293)
at org.apache.maven.cli.MavenCli.main (MavenCli.java:196)
at jdk.internal.reflect.DirectMethodHandleAccessor.invoke (DirectMethodHandleAccessor.java:103)
at java.lang.reflect.Method.invoke (Method.java:580)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced (Launcher.java:283)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch (Launcher.java:226)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode (Launcher.java:407)
at org.codehaus.plexus.classworlds.launcher.Launcher.main (Launcher.java:348)
Caused by: org.apache.maven.plugin.PluginExecutionException: Execution codestyle_check of goal com.diffplug.spotless:spotless-maven-plugin:2.43.0:check failed: java.io.IOException: Failed to load eclipse jdt formatter: java.lang.RuntimeException: org.tukaani.xz.XZFormatException: Input is not in the XZ format
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo (DefaultBuildPluginManager.java:148)
at org.apache.maven.lifecycle.internal.MojoExecutor.doExecute2 (MojoExecutor.java:370)
Caused by: com.diffplug.spotless.ThrowingEx$WrappedAsRuntimeException: java.io.IOException: Failed to load eclipse jdt formatter: java.lang.RuntimeException: org.tukaani.xz.XZFormatException: Input is not in the XZ format
at com.diffplug.spotless.ThrowingEx.asRuntime (ThrowingEx.java:92)
at com.diffplug.spotless.LazyForwardingEquality.state (LazyForwardingEquality.java:58)
at com.diffplug.spotless.LazyForwardingEquality.toBytes (LazyForwardingEquality.java:85)
at com.diffplug.spotless.LazyForwardingEquality.hashCode (LazyForwardingEquality.java:102)
at java.util.ArrayList.hashCodeRange (ArrayList.java:677)
at java.util.ArrayList.hashCode (ArrayList.java:664)
at com.diffplug.spotless.Formatter.hashCode (Formatter.java:276)
at java.util.HashMap.hash (HashMap.java:338)
at java.util.HashMap.put (HashMap.java:618)
at com.diffplug.spotless.maven.FormattersHolder.create (FormattersHolder.java:43)
at com.diffplug.spotless.maven.AbstractSpotlessMojo.execute (AbstractSpotlessMojo.java:232)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo (DefaultBuildPluginManager.java:137)
Caused by: java.io.IOException: Failed to load eclipse jdt formatter: java.lang.RuntimeException: org.tukaani.xz.XZFormatException: Input is not in the XZ format
at com.diffplug.spotless.extra.EquoBasedStepBuilder.get (EquoBasedStepBuilder.java:116)
at com.diffplug.spotless.FormatterStepImpl.calculateState (FormatterStepImpl.java:58)
at com.diffplug.spotless.LazyForwardingEquality.state (LazyForwardingEquality.java:56)
Caused by: java.lang.RuntimeException: org.tukaani.xz.XZFormatException: Input is not in the XZ format
at dev.equo.solstice.p2.Unchecked.wrap (Unchecked.java:25)
at dev.equo.solstice.p2.P2Model.query (P2Model.java:144)
at com.diffplug.spotless.extra.EquoBasedStepBuilder.get (EquoBasedStepBuilder.java:114)
Caused by: org.tukaani.xz.XZFormatException: Input is not in the XZ format
at org.tukaani.xz.common.DecoderUtil.decodeStreamHeader (Unknown Source)
at org.tukaani.xz.SingleXZInputStream.<init> (Unknown Source)
at org.tukaani.xz.XZInputStream.<init> (Unknown Source)
at dev.equo.solstice.p2.P2Client.resolveXml (P2Client.java:300)
at dev.equo.solstice.p2.P2Client.addUnits (P2Client.java:102)
at dev.equo.solstice.p2.P2Session.populateFrom (P2Session.java:34)
at dev.equo.solstice.p2.P2Model.queryRaw (P2Model.java:107)
at dev.equo.solstice.p2.P2Model.query (P2Model.java:136)
[ERROR]
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
