OH2 snapshot from 5/16 under Windows 8.1.
Aeotect ZW111 nano dimmer f/w v1.2 with their zstick controller.
Created a Switch Item and Dimmer Item, connected each to the appropriate Channel on the ZW111 dimmer Thing.
Within “HABmin -> Configuration -> Things -> Z-Wave Node 2 -> Description” I can toggle both the Switch and Dimmer items with the ON/OFF toggle presented, and this makes the associated light bulb turn ON and OFF as expected.
Within “HABmin -> Sitemaps -> Home -> Things -> Z-Wave Node 2” I am also presented with the 2 Items and their respective ON/OFF toggles. The Dimmer toggle works and changes the light bulb state, but the Switch toggle does nothing.
Also, is there no feedback from this device? Toggling one does not update the state of the other. Or is it expected that each Channel is completely independent and therefore may not represent the actual state of the device?
Also, PaperUI does not update the network key config entry, as verified by Aeotec’s backup utility.
Also, PaperUI does not seem to understand when the USB controller has been pulled, and change the state from ONLINE to something else.
Also, openHAB2 should read the config of the dimmer during initialization and reconcile the differences.
Also, if I delete the ZW111 dimmer Thing, then use SUC query and add the dimmer Thing back in, the Dimmer Item is somehow and unexpectedly already attached to the corresponding Channel on the brand new Thing (well, most of the time it is, though occasionally not). But the Switch Item is not attached (as one would expect).
