Hi all,
Wondering if i can get an example of your Insteon Leak Sensor item?
Im assuming the switch item can be used along with a transform file of some kind but i would love to hear from the community.
Thank you in advanced for any assistance you can provide.
steve1
(steve1)
May 22, 2016, 10:26am
2
This is what I use…
Items
Contact LeakSensor_1 "Leak Sensor [MAP(leak.map):%s]" {insteonplm="XX.XX.XX:FXX.00.0A#contact"}
DateTime LeakSensor_1_LastHeardFrom "Leak Sensor Last Msg Time [%1$tm/%1$td/%1$tY %1$tH:%1$tM]" {insteonplm="XX.XX.XX:FXX.00.0A#lastheardfrom"}
leak.map
OPEN=dry
CLOSED=wet
-=unknown
Appreciate you Steve. Slowly but surely ill work towards turning into a contributor in the community. Hope you are having a great weekend.
craigh
(Craig)
September 12, 2016, 10:22pm
4
Steve,
What should be substituted for the XX after the :F? I haven’t seen that notation anywhere. I am trying to set up a leak sensor (2852-222).
thanks,
craig
craigh
(Craig)
September 12, 2016, 10:34pm
5
Never mind, I figured out it was the product key.
I am a little confused though, why would you have X’d out the product key part when giving an example of a leak sensor config? Are there other product keys which could be used?
thanks,
craig
I suspect Steve overshot when XX’ing out, spilling from the address into the product key
