Hi Udo,
thanks for the fast reply. The log statement was just to get a handle on the overal problems I am facing here.
What I eventually would like to achieve is to check for all my sensors when they have been updated the last time and for the items which are not initialized I would use the time openhab was started as the basis for the offset.
But anyway, I changed the statement as you suggested and get now a different exception.
The exception changed…
2016-01-01 20:20:20.006 [INFO ] [org.openhab.model.script.sensor alivecheck ] - in rule
2016-01-01 20:20:20.012 [INFO ] [org.openhab.model.script.Openhab start ] - 2016-01-01T17:42:25
2016-01-01 20:20:20.044 [ERROR] [.openhab.model.rule.internal.engine.ExecuteRuleJob] - Error during the execution of rule Check Sensor liveliness
java.lang.IllegalStateException: Ambiguous methods [protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAssignment(org.eclipse.xtext.xbase.XAssignment,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(org.eclipse.xtext.xbase.XBlockExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBooleanLiteral(org.eclipse.xtext.xbase.XBooleanLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateCastedExpression(org.eclipse.xtext.xbase.XCastedExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateClosure(org.eclipse.xtext.xbase.XClosure,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateConstructorCall(org.eclipse.xtext.xbase.XConstructorCall,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected org.eclipse.xtext.xbase.interpreter.IEvaluationResult org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateDoWhileExpression(org.eclipse.xtext.xbase.XDoWhileExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateForLoopExpression(org.eclipse.xtext.xbase.XForLoopExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateIfExpression(org.eclipse.xtext.xbase.XIfExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateInstanceOf(org.eclipse.xtext.xbase.XInstanceOfExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateMemberFeatureCall(org.eclipse.xtext.xbase.XMemberFeatureCall,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateNullLiteral(org.eclipse.xtext.xbase.XNullLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateNumberLiteral(org.eclipse.xtext.xbase.XNumberLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateReturnExpression(org.eclipse.xtext.xbase.XReturnExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateStringLiteral(org.eclipse.xtext.xbase.XStringLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateSwitchExpression(org.eclipse.xtext.xbase.XSwitchExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateThrowExpression(org.eclipse.xtext.xbase.XThrowExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateTryCatchFinallyExpression(org.eclipse.xtext.xbase.XTryCatchFinallyExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateTypeLiteral(org.eclipse.xtext.xbase.XTypeLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateVariableDeclaration(org.eclipse.xtext.xbase.XVariableDeclaration,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateWhileExpression(org.eclipse.xtext.xbase.XWhileExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator)] for params [null, org.eclipse.xtext.xbase.interpreter.impl.DefaultEvaluationContext@8614f5, org.eclipse.xtext.util.CancelIndicator$1@17445a2]
at org.eclipse.xtext.util.PolymorphicDispatcher.handleAmbigousMethods(PolymorphicDispatcher.java:308) ~[na:na]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:283) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:28) ~[na:na]
at com.sun.proxy.$Proxy86.apply(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.lib.IterableExtensions.forEach(IterableExtensions.java:395) ~[na:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0]
at java.lang.reflect.Method.invoke(Method.java:483) ~[na:1.8.0]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:729) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:713) ~[na:na]
at sun.reflect.GeneratedMethodAccessor56.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na]
at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateMemberFeatureCall(XbaseInterpreter.java:549) ~[na:na]
at sun.reflect.GeneratedMethodAccessor50.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na]
at sun.reflect.GeneratedMethodAccessor57.invoke(Unknown Source) ~[na:na]
at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) ~[na:na]
at org.openhab.model.rule.internal.engine.ExecuteRuleJob.execute(ExecuteRuleJob.java:55) ~[na:na]
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [quartz-all-2.1.7.jar:na
