After upgrading my 2.1 install to the latest 2.2 snapshot #1004 my logs are filled with item registry warnings on server startup and non of my items managed thorough the JSONDB appear to have any groups any more.
The groups are still present within the jsondb files and i can’t find any obvious error. Error messages appear to be generated after loading the influxdb persistence model so i’m not sure if it’s part of that, but seems unlikely
Any suggestions on if this is a bug in the latest snapshot or with my setup are definitely welcome!
7:36:49.867 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Hallway_Evohome_CurrentSetPoint' already exists! Failed to add a second with the same UID!
17:36:49.880 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.StringItem with key'Landing_Evohome_SetPointStatus' already exists! Failed to add a second with the same UID!
17:36:49.881 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'Lounge_Mainlight1_Dimmer' already exists! Failed to add a second with the same UID!
17:36:49.882 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'Lounge_Mainlight2_Dimmer' already exists! Failed to add a second with the same UID!
17:36:49.883 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Conservatory_Evohome_CurrentSetPoint' already exists! Failed to add a second with the same UID!
17:36:49.884 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'Hallway_Multisensor_SensorLuminance' already exists! Failed to add a second with the same UID!
17:36:49.888 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Landing_Evohome_CurrentSetPoint' already exists! Failed to add a second with the same UID!
17:36:49.890 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.StringItem with key'Lounge_Evohome_SetPointStatus' already exists! Failed to add a second with the same UID!
17:36:49.891 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'DiningRoom_WallLight_Dimmer' already exists! Failed to add a second with the same UID!
17:36:49.892 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.StringItem with key'Bedroom2_Evohome_SetPointStatus' already exists! Failed to add a second with the same UID!
17:36:49.896 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'Lounge_Shield_Online' already exists! Failed to add a second with the same UID!
17:36:49.903 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.StringItem with key'OfficeEvohome_SetPointStatus' already exists! Failed to add a second with the same UID!
17:36:49.904 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'Lounge_Multisensor_SensorLuminance' already exists! Failed to add a second with the same UID!
17:36:49.905 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'Hallway_Mainlight_Switch' already exists! Failed to add a second with the same UID!
17:36:49.907 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Office_Evohome_CurrentSetPoint' already exists! Failed to add a second with the same UID!
17:36:49.908 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'Hallway_Multisensor_SensorMotion' already exists! Failed to add a second with the same UID!
17:36:49.908 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.StringItem with key'Bedroom1_Evohome_SetPointStatus' already exists! Failed to add a second with the same UID!
17:36:49.911 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'Hallway_Multisensor_BatteryLevel' already exists! Failed to add a second with the same UID!
17:36:49.912 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'Office_Multisensor_SensorMotion' already exists! Failed to add a second with the same UID!
17:36:49.913 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'Bedroom2_Mainlight_Dimmer' already exists! Failed to add a second with the same UID!
17:36:49.914 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'Office_Mainlight_Dimmer' already exists! Failed to add a second with the same UID!
17:36:49.918 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.StringItem with key'Bedroom4_Evohome_SetPointStatus' already exists! Failed to add a second with the same UID!
17:36:49.918 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'Kitchen_Multisensor_SensorMotion' already exists! Failed to add a second with the same UID!
17:36:49.919 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'Lounge_Multisensor_BatteryLevel' already exists! Failed to add a second with the same UID!
17:36:49.920 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'Kitchen_Mainlight2_Dimmer' already exists! Failed to add a second with the same UID!
17:36:49.924 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Landing_Evohome_Temperature' already exists! Failed to add a second with the same UID!
17:36:49.924 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Office_Multisensor_SensorLuminance' already exists! Failed to add a second with the same UID!
17:36:49.928 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Bedroom4_Evohome_CurrentSetPoint' already exists! Failed to add a second with the same UID!
17:36:49.928 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'Lounge_Samsung55TV_Online' already exists! Failed to add a second with the same UID!
17:36:49.929 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Conservatory_Evohome_Temperature' already exists! Failed to add a second with the same UID!
17:36:49.930 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'Lounge_Walllights_Dimmer' already exists! Failed to add a second with the same UID!
17:36:49.930 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Bedroom2_Evohome_CurrentSetPoint' already exists! Failed to add a second with the same UID!
17:36:49.931 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'Presence_Vibs_Oneplus3_Online' already exists! Failed to add a second with the same UID!
17:36:49.931 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'Kitchen_Multisensor_SensorLuminance' already exists! Failed to add a second with the same UID!
17:36:49.932 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'DiningRoom_Evohome_CurrentSetPoint' already exists! Failed to add a second with the same UID!
17:36:49.933 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'Kitchen_Mainlight1_Dimmer' already exists! Failed to add a second with the same UID!
17:36:49.935 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.StringItem with key'Hallway_Evohome_SetPointStatus' already exists! Failed to add a second with the same UID!
17:36:49.936 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'1FOffice_Mainlight_Dimmer' already exists! Failed to add a second with the same UID!
17:36:49.937 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'1FOffice_Evohome_Temperature' already exists! Failed to add a second with the same UID!
17:36:49.937 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.StringItem with key'ConservatoryEvohome_SetPointStatus' already exists! Failed to add a second with the same UID!
17:36:49.939 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Bedroom4_Evohome_Temperature' already exists! Failed to add a second with the same UID!
17:36:49.943 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'DiningRoom_MainLight_Dimmer' already exists! Failed to add a second with the same UID!
17:36:49.944 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Lounge_Evohome_CurrentSetPoint' already exists! Failed to add a second with the same UID!
17:36:49.945 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'Presence_Nikki_OnePlusX_Online' already exists! Failed to add a second with the same UID!
17:36:49.945 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'Bedroom1_Mainlight_Dimmer' already exists! Failed to add a second with the same UID!
17:36:49.946 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Bedroom2_Evohome_Temperature' already exists! Failed to add a second with the same UID!
17:36:49.952 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Lounge_Evohome_Temperature' already exists! Failed to add a second with the same UID!
17:36:49.953 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.ColorItem with key'Node24_RGBW_Color' already exists! Failed to add a second with the same UID!
17:36:49.953 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'1FBathroom_Evohome_Temperature' already exists! Failed to add a second with the same UID!
17:36:49.954 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.StringItem with key'EvoTouch_Mode' already exists! Failed to add a second with the same UID!
17:36:49.954 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Bathroom_Evohome_CurrentSetPoint' already exists! Failed to add a second with the same UID!
17:36:49.955 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Bedroom1_Evohome_CurrentSetPoint' already exists! Failed to add a second with the same UID!
17:36:49.975 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'DiningRoom_Evohome_Temperature' already exists! Failed to add a second with the same UID!
17:36:49.975 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'ZWaveNode23FGRGBWRGBWController_Dimmer3' already exists! Failed to add a second with the same UID!
17:36:49.975 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'ZWaveNode23FGRGBWRGBWController_Dimmer5' already exists! Failed to add a second with the same UID!
17:36:49.975 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'ZWaveNode23FGRGBWRGBWController_Dimmer4' already exists! Failed to add a second with the same UID!
17:36:49.975 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'Lounge_Multisensor_SensorMotion' already exists! Failed to add a second with the same UID!
17:36:49.976 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'Kitchen_Multisensor_BatteryLevel' already exists! Failed to add a second with the same UID!
17:36:49.976 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'ZWaveNode23FGRGBWRGBWController_Dimmer1' already exists! Failed to add a second with the same UID!
17:36:49.976 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'1FOffice_Evohome_CurrentSetPoint' already exists! Failed to add a second with the same UID!
17:36:49.976 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'Bedroom4_Mainlight_Dimmer' already exists! Failed to add a second with the same UID!
17:36:49.979 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Office_Evohome_Temperature' already exists! Failed to add a second with the same UID!
17:36:49.980 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Hallway_Evohome_Temperature' already exists! Failed to add a second with the same UID!
17:36:49.980 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.StringItem with key'Bathroom_Evohome_SetPointStatus' already exists! Failed to add a second with the same UID!
17:36:49.983 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.StringItem with key'1FOfficeEvohome_SetPointStatus' already exists! Failed to add a second with the same UID!
17:36:49.984 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'Landing_Mainlight_Dimmer' already exists! Failed to add a second with the same UID!
Any idea who I could ask? I’m stuck with no idea how to troubleshoot, delete the items or fix the issue… who “owns” this part of OH2 (and what part is it)?
Update: This issue is intermittent for me on build 1023. Three of four times on an OH2 restart I will get this error - but every once in a while it loads fine.
Currently on snapshot 1043 and I’m still getting these errors on startup. I’d guesss that Openhab is starting up correctly <1 in 10 times. No errors beyond the duplicate item issues.
I’m having this annoying issue as well…sometimes when snapshot updating in between builts via apt-get it gets fixed, but after another restart of the service again I loose lables for items that are defined via PaperUI. The items i defined simply in items file are all fine.
Is there anything we could provide in order to get it fixed or know a procedure to repair our systems.
Many Thanks, Norbert
2017-10-24 08:18:16.713 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.RollershutterItem with key'ZWaveNode6FGRM222RollerShutter_BlindsControl' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.714 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'ZWaveNode16FGSD002SmokeDetector_HeatAlarm' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.717 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'ZWaveNode7FGRM222RollerShutter_LamellaPosition' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.719 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'Christian_iPhone6S_Online' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.722 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode14FGRM222RollerShutter_SensorPower' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.724 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode17FGS213SingleSwitch2_SensorPower' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.727 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode3FGRM222RollerShutter_SensorPower' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.729 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Sonnenstand_Radiation_DirectRadiation' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.732 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'MariaMagdalena_iPhone6S_Online' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.734 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode13FGRM222RollerShutter_SensorPower' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.737 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.StringItem with key'KostalInverter_Status' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.739 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'ZWaveNode13FGRM222RollerShutter_LamellaPosition' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.743 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.RollershutterItem with key'ZWaveNode5FGRM222RollerShutter_BlindsControl' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.745 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode16FGSD002SmokeDetector_BatteryLevel' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.748 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'ZWaveNode12FGRM222RollerShutter_LamellaPosition' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.750 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'KostalInverter_DayEnergy' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.752 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DateTimeItem with key'Christian_iPhone6S_LastSeen' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.755 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode16FGSD002SmokeDetector_TemperatureSensor' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.757 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Christian_iPhone6S_LatencyMs' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.760 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode12FGRM222RollerShutter_SensorPower' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.762 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.RollershutterItem with key'ZWaveNode7FGRM222RollerShutter_BlindsControl' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.764 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'ZWaveNode11FGRM222RollerShutter_LamellaPosition' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.767 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode11FGRM222RollerShutter_SensorPower' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.769 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.RollershutterItem with key'ZWaveNode11FGRM222RollerShutter_BlindsControl' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.772 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'MariaMagdalena_iPhone6S_LatencyMs' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.774 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode15FGS213SingleSwitch2_ElectricMeterWatts' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.777 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode2ZW100MultiSensor6_SensorUltraviolet' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.780 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.RollershutterItem with key'ZWaveNode14FGRM222RollerShutter_BlindsControl' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.782 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode2ZW100MultiSensor6_BatteryLevel' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.785 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode6FGRM222RollerShutter_SensorPower' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.787 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode2ZW100MultiSensor6_SensorTemperature' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.789 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'KostalInverter_TotalEnergy' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.791 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode2ZW100MultiSensor6_SensorRelativeHumidity' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.794 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode17FGS213SingleSwitch2_ElectricMeterKWh' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.796 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'ZWaveNode17FGS213SingleSwitch2_Switch' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.798 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode5FGRM222RollerShutter_SensorPower' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.801 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'ZWaveNode3FGRM222RollerShutter_LamellaPosition' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.803 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode10FGRM222RollerShutter_SensorPower' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.805 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.RollershutterItem with key'ZWaveNode13FGRM222RollerShutter_BlindsControl' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.808 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'ZWaveNode16FGSD002SmokeDetector_SmokeAlarm' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.810 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'ZWaveNode10FGRM222RollerShutter_LamellaPosition' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.812 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.RollershutterItem with key'ZWaveNode3FGRM222RollerShutter_BlindsControl' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.815 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.RollershutterItem with key'ZWaveNode12FGRM222RollerShutter_BlindsControl' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.817 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'ZWaveNode6FGRM222RollerShutter_LamellaPosition' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.819 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DateTimeItem with key'Sonnenstand_CivilDawn_StartTime' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.822 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.RollershutterItem with key'ZWaveNode10FGRM222RollerShutter_BlindsControl' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.824 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'ZWaveNode14FGRM222RollerShutter_LamellaPosition' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.827 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode2ZW100MultiSensor6_SensorLuminance' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.829 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'ZWaveNode16FGSD002SmokeDetector_LowBatteryAlarm' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.832 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DateTimeItem with key'MariaMagdalena_iPhone6S_LastSeen' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.834 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode7FGRM222RollerShutter_SensorPower' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.836 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DateTimeItem with key'Sonnenstand_CivilDusk_StartTime' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.839 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode17FGS213SingleSwitch2_ElectricMeterWatts' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.841 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DimmerItem with key'ZWaveNode5FGRM222RollerShutter_LamellaPosition' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.843 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode15FGS213SingleSwitch2_SensorPower' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.845 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'ZWaveNode15FGS213SingleSwitch2_Switch' already exists! Failed to add a second with the same UID!
2017-10-24 08:18:16.847 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'KostalInverter_ACPower' already exists! Failed to add a second with the same UID!
Hard to believe… Version 2.2 after more than two years development and we have to start openhab2 9-12 times until it works. I’ve tried OH2 since the first alpha-version but i’m still on OH1 due to such errors.
Don’t talk in general, I’m seeing this issue only once in a while (about one in 10 restarts).
openHAB 2.2 runs extremely stable since around builds #980 and up. And I always upgrade as soon as an ESH update is pushed into the distro (about every two weeks)
May be not in general, but with my zwave devices only one of 10 restarts doesn’t need further restarts and if the problem occurs, then at least 6 restarts are necessary (more than 10 are also possible). It took me a long time to realize, that restarting openhab resolves the problem.
I’m pretty sure there is some other problem with your system which causes this.
Either related to a hardware issue (weak power supply, …) or maybe from tinkering around with different settings there may be some leftovers in the cache or whatever. Also dead nodes may cause this or nodes which were not properly excluded from the network.
If it were a general problem we would read a lot more of similar issues in this forum.
