I use the Onkyo binding for controlling my AV. When changing the source, the channel zone1#input
returns a number. When I link the item to it, it makes a decimal number of it. So it gets eg 35.0
insead of just 35
. As you see, I have a .map linked to the item and offcourse this is not working. Why do I get 35.0
? I now changed the item to a String, problem solved, but this is not the way to go I think.
Number Onkyo_Zone1_Input "Input Source Z1" (Onkyo) ["Control"] {channel="onkyo:TX-NR717:av:zone1#input", stateDescription="sources"[pattern="MAP(onkyo_sources.map):%s"]
