I´m using OH 3 and try to get my first script (out of a rule) runnig.
I allready reduced it to a minimum of code But I have no idea any more to solve my small problem.
I just like to write a number to an (number) item:
logger.info ("TEST");
//var Number Verbrauch = itemRegistry.getItem("StromzahlerSML_Bezug").deltaSince(now.minusMinutes(1))*10;
//itemRegistry.getItem("Strom_Verbrauch_Aktuell").postUpdate(Verbrauch);
//var PersistenceExtensions = Java.type("org.openhab.core.persistence.extensions.PersistenceExtensions");
//var Number Verbrauch_heute = 123;// itemRegistry.getItem("StromzahlerSML_Bezug").deltaSince(now.withTimeAtStartOfDay);
var item = itemRegistry.getItem("Strom_Verbrauch_Aktuell");
item.postUpdate(1234);
This Error is thrown:
2023-02-27 19:41:55.088 [INFO ] [.rule.Stromzaehler_Verbrauch_Aktuell] - TEST
2023-02-27 19:41:55.095 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Stromzaehler_Verbrauch_Aktuell' failed: TypeError: item.postUpdate is not a function in <eval> at line number 13
Which rules language? This looks like Nashorn JavaScript (aka ECMAScript 5.1) but if you are just getting started, you should use the JS Scripting add-on instead. Nashorn is way out of date at this point and if you are concerned about needing to install a separate add-on, don’t be. In OH 4 Nashorn will need to be installed as an add-on too.
Despite what you might think from looking at the syntax for Rules DSL, the Item class from openHAB does not actually implement postUpdate() nor sendCommand(). It only looks like it’s a method on Item due to some behind the scene trickery in rules DSL.
In Nashorn JavaScript, you don’t get to benefit from any trickery at all. So you need to use the actual implemented method on the event bus events("NameOfItem", "State as String");
Note that the persistence actions aren’t really on the Item class either and you need to import and use PersistenceExtensions to make calls like deltaSince.
In JS Scripting there is a fantastic helper library that comes with the add-on which provides a pure JavaScript interface to openHAB. In this interface, postUpdate() and sendCommand are added to the JavaScript Item class, along with a ton of other useful stuff which makes working in rules much nicer.
Your rule above with the latest openhab-js helper library would be something like:
console.info("TEST");
var Verbrauch = items['StromzahlerSML_Bezug'].deltaSince(time.toZDT().minusMinutes(1))*10;
items['Strom_Verbrauch_Aktuell'].postUpdate(Verbrauch);
The reference docs for JS Scripting are quite thorough and complete.
Thank´s for your post. You were right it was ECMA 5.1.
I installed now the addon JSScripting (ECMAScript-2021).
At this point I´m not shure if I could follow you:
I got it like these functions should now be useable with JSScripting, correct?
Or do I need to install or activate such “helper libaries” by hand?
I´m still not able to get this small examples running (in ECMA-2021 / JSScripting):
Just by the way: The Item is of type number now… So this is why I removed the “” in the code.
events.postUpdate("Strom_Verbrauch_Aktuell", 1234);
brings
2023-02-28 19:21:24.688 [WARN ] [.internal.OpenhabGraalJSScriptEngine] - Failed to retrieve script script dependency listener from engine bindings. Script dependency tracking will be disabled.
2023-02-28 19:21:26.458 [INFO ] [ab.automation.script.ui.Stromzaehler] - TEST
2023-02-28 19:21:26.460 [ERROR] [b.automation.script.javascript.stack] - Failed to execute script:
org.graalvm.polyglot.PolyglotException: ReferenceError: "events" is not defined
at <js>.:program(<eval>:3) ~[?:?]
at org.graalvm.polyglot.Context.eval(Context.java:379) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:458) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:426) ~[?:?]
at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:264) ~[java.scripting:?]
at org.openhab.automation.jsscripting.internal.scriptengine.DelegatingScriptEngineWithInvocableAndAutocloseable.eval(DelegatingScriptEngineWithInvocableAndAutocloseable.java:51) ~[?:?]
at org.openhab.automation.jsscripting.internal.scriptengine.InvocationInterceptingScriptEngineWithInvocableAndAutoCloseable.eval(InvocationInterceptingScriptEngineWithInvocableAndAutoCloseable.java:69) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:58) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:183) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:55) ~[?:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1181) ~[?:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runNow(RuleEngineImpl.java:1033) ~[?:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runNow(RuleEngineImpl.java:1049) ~[?:?]
at org.openhab.core.automation.rest.internal.RuleResource.runNow(RuleResource.java:327) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:179) ~[bundleFile:3.4.5]
at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:96) ~[bundleFile:3.4.5]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:201) ~[bundleFile:3.4.5]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:104) ~[bundleFile:3.4.5]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:59) ~[bundleFile:3.4.5]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:96) ~[bundleFile:3.4.5]
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:265) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:225) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:298) ~[bundleFile:3.4.5]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doPost(AbstractHTTPServlet.java:217) ~[bundleFile:3.4.5]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) ~[bundleFile:3.1.0]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:273) ~[bundleFile:3.4.5]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:550) ~[bundleFile:9.4.46.v20220331]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:74) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440) ~[bundleFile:9.4.46.v20220331]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294) ~[bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[bundleFile:9.4.46.v20220331]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:90) ~[bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.46.v20220331]
2023-02-28 19:21:26.471 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Stromzaehler' failed: org.graalvm.polyglot.PolyglotException: ReferenceError: "events" is not defined
And this snippet of code:
items['Strom_Verbrauch_Aktuell'].postUpdate(123);
Brings this Error:
2023-02-28 19:24:17.416 [WARN ] [.internal.OpenhabGraalJSScriptEngine] - Failed to retrieve script script dependency listener from engine bindings. Script dependency tracking will be disabled.
2023-02-28 19:24:18.921 [INFO ] [ab.automation.script.ui.Stromzaehler] - TEST
2023-02-28 19:24:18.924 [ERROR] [b.automation.script.javascript.stack] - Failed to execute script:
org.graalvm.polyglot.PolyglotException: TypeError: undefined has no such function "postUpdate"
at jdk.internal.reflect.GeneratedMethodAccessor64.invoke(Unknown Source) ~[?:?]
2023-02-28 19:24:18.949 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Stromzaehler' failed: org.graalvm.polyglot.PolyglotException: TypeError: undefined has no such function "postUpdate"
Am I´m missing something to include in the beginning of the script?
I searched a lot again in the web but other users seems to be okay with such easy lines of code.
The library comes with the add-on. There’s nothing separate to install, unless for some reason you need something in a newer version of openhab-js than shipped with your version of the add-on.
Please review the documentation for the JS Scripting add-on. Everything is documented there with examples.
YES! Thanks. This small line of code is working now
Thank´s for bringing me back on the track. As much as I was editing the code, the code was getting worster. Now I have a small light at the end of the tunnel. So basically the system works and I have to read more in detail in the documentation. It´s crazy (for me) how important the version of add-on is. Up to know I just read a lot of web content but mostly without the information which version of JS was used.
BTW: I was also able to crash OH3 with my few lines of code, the rules were not loading anymore. So I restartet the server so everything is fine again
The add-on and the corresponding helper library are very new, relatively speaking. For all intents and purposes it’s still under development. I’d expect significant changes (usually non-breaking) to continue to be added at least for the next year or so.
Note, the items.getItem('ItemName') syntax is still supported in openhab-js 4.0+. In 4.0 though a new feature was added that allows the items['ItemName'] and items.ItemName syntax.
