Item shall be persisted which is not configured to do that
  • Platform information:
    • Hardware: x86_64/8GB/
    • openhab/openhab:4.1.2
    • Java Runtime Environment: java-17-openjdk-amd64
    • openHAB version: 4.1.2
  • Issue of the topic: Openhab tries to persist items that are not configured to persist
    • Items configuration related to the issue:
    • “Astronomische_Sonnendaten_Daylight_Start”: {
      “class”: “org.openhab.core.items.ManagedItemProvider$PersistedItem”,
      “value”: {
      “groupNames”: [
      “Astronomische_Sonnendaten”
      “itemType”: “DateTime”,
      “tags”: [
      “Point”
      “label”: “Startzeit_Tageslicht”,
      “category”: “”
jdbc-mariadb.persist:
// persistence strategies have a name and definition and are referred to in the "Items" section
Strategies {
        everyHour : "0 0 * * * ?"
        everyDay  : "0 0 0 * * ?"
Filters {
        fivepercent : > % 5
        atMostOnceAMinute : T 1 m
 * Each line in this section defines for which Item(s) which strategy(ies) should be applied.
 * You can list single items, use "*" for all items or "groupitem*" for all members of a group
 * Item (excl. the group Item itself).
Items {
        // persist the Item state of Heating_Mode and Notifications_Active on every change and restore them from the db at startup
        here are my items:
        strategy = everyChange, restoreOnStartup
        // additionally, persist all temperature and weather values every hour
        all_bwm_group* : strategy = everyChange, restoreOnStartup
  • Sitemap configuration related to the issue
  • Rules code related to the issue
  • Services configuration related to the issue
  • If logs where generated please post these here using code fences:
  • org.openhab.persistence.jdbc.internal.exceptions.JdbcSQLException: Error in SQL query!!!; (conn=1727) Table ‘openhab.astronomische_sonnendaten_daylight_start_0004’ doesn’t exist Query: INSERT INTO astronomische_sonnendaten_daylight_start_0004 (time, value) VALUES( NOW(3), ? ) ON DUPLICATE KEY UPDATE VALUE= ? Parameters: [2025-02-24 06:18:00.0, 2025-02-24 06:18:00.0]; Pool Name= yank-default; SQL= INSERT INTO astronomische_sonnendaten_daylight_start_0004 (time, value) VALUES( NOW(3), ? ) ON DUPLICATE KEY UPDATE VALUE= ?
You are not showing the full configuration so :man_shrugging:
“here are my items” is very much the part that we need to see.
Binareingang_EG_32fach_11040_Aussen_Abfahrt_BWM_Kanal_H2,Binareingang_EG_32fach_11040_DG_BWM,Binareingang_EG_32fach_11040_DG_Reedkontakt,Binareingang_EG_32fach_11040_EG_Arbeitszimmer_Fenster_Reed_11040_P1,Binareingang_EG_32fach_11040_EG_Bad_Reedkontakt_Channel_J,Binareingang_EG_32fach_11040_EG_Esszimmer_Schiebetur_Reedkontakt,Binareingang_EG_32fach_11040_EG_Flur_BWM_gegenuber_WC_,Binareingang_EG_32fach_11040_EG_Garagentur_Reedkontakt,Binareingang_EG_32fach_11040_EG_Haustur_Reedkontakt,Binareingang_EG_32fach_11040_EG_Kuche_Terassentur_Reedkontakt,Binareingang_EG_32fach_11040_EG_WC_Reed_Oberlichter_links,Binareingang_EG_32fach_11040_EG_WC_Reedkontakt,Binareingang_EG_32fach_11040_EG_Wohnzimmer_Reed_Oberlichter_rechts,Binareingang_EG_32fach_11040_Garage_Fenster_Reedkontakt,Binareingang_EG_32fach_11040_Garage_Tur_Balkon_Reedkontakt,Binareingang_EG_32fach_11040_Garagentor_Reedkontakt,Binareingang_EG_32fach_11040_Outdoorkitchen_BWM_I2,Binareingang_EG_32fach_11040_Scene_Name,Binareingang_EG_32fach_11040_Szenen_Kanal,Binareingang_EG_32fach_EG_BWM_TRH_Decke_bei_Garagentur,Binareingang_EG_32fach_EG_Bad_BWM,Binareingang_EG_32fach_EG_Flur_BWM_vor_Arbeitszimmer,Binareingang_EG_32fach_EG_TRH_BWM_Decke_vor_Garagentur,Binareingang_EG_32fach_EG_WC_BWM,Dimmaktor_EG_14_11030,Dimmaktor_EG_14_11030_EG_Arbeitszimmer_Dimmer_Raum,Dimmaktor_EG_14_11030_EG_Flur_Dimmer,Dimmaktor_EG_14_11030_EG_Kochinsel,Dimmaktor_EG_14_11030_EG_TRH_Licht,Dimmaktor_EG_14_11030_EG_TRH_Licht_Treppenlichtfunktion,Dimmaktor_EG_14_11030_EG_WC_Licht,Dimmaktor_EG_14_11030_Licht_TRH_oben,Dimmaktor_EG_58_AKD040102_4fach_11031_EG_Kuche_dimmen,Dimmaktor_EG_58_AKD040102_4fach_Dimmer_EG_Arbeitszimmer_Schreibtisch,Dimmaktor_EG_58_AKD040102_4fach_EG_Bad_Waschbecken_Dimmer,Doorbird,Doorbird_D210x_Doorbell__unten,Doorbird_Eingang_oben,Doorbird_Eingang_oben_Bewegung,Doorbird_Eingang_oben_Doorbell_History_Image,Doorbird_Eingang_oben_Doorbell_History_Index,Doorbird_Eingang_oben_Doorbell_History_Timestamp,Doorbird_Eingang_oben_Doorbell_Montage_Image,Doorbird_Eingang_oben_Doorbell_Pressed_Image,Doorbird_Eingang_oben_Doorbell_Timestamp,Doorbird_Eingang_oben_Image,Doorbird_Eingang_oben_Image_Timestamp,Doorbird_Eingang_oben_Light,Doorbird_Eingang_oben_Motion_Detected_Image,Doorbird_Eingang_oben_Motion_History_Image,Doorbird_Eingang_oben_Motion_History_Index,Doorbird_Eingang_oben_Motion_History_Timestamp,Doorbird_Eingang_oben_Motion_Montage_Image,Doorbird_Eingang_oben_Motion_Timestamp,Doorbird_Eingang_oben_Open_Door_1,Doorbird_Eingang_oben_Open_Door_2,EGAKS081603_Schaltaktor11021_EG_Wohnzimmer_Steckdose_Receiver_,EGAKS081603_Schaltaktor11021_EG_Wohnzimmer_Steckdose_Weihnachtsbaum,EGAKS081603_Schaltaktor11021_Garage_Licht_Mitte,EG_Eingang_Flur_WC_FBH_manuelle_Sollwertverschiebung_2Byte,EG_ARbeitszimmer_FBH_manuelle_Sollwertverschiebung_2_Byte,EG_Heizaktor_11010_EG_Arbeitszimmer_FBH_Sollwert_vorgeben,EG_Arbeitszimmer_FBH_Stellwert_Heizen_Status_senden,EG_Arbeitszimmer_FBH_Temperaturwert_empfangen,EG_Arbeitszimmer_FBH_Ventilzustand_senden,EG_Heizaktor_11010_EG_Arbeitszimmer_FBH_aktueller_Sollwert_senden,EG_Heizaktor_11010_EG_Bad_FBH_Sollwert,EG_Heizaktor_11010_EG_Bad_FBH_Ventilzustand,EG_Heizaktor_11010_EG_Bad_Ist_Temperatur,EG_Heizaktor_11010_EG_Bad_Manuelle_Sollwertverschiebung,EG_Heizaktor_11010_EG_Bad_Stellwert_FBH,EG_EingangFlurWC_FBH_Status_Stellwert_Heizen,EG_EingangFlurWC_FBH_Ventilzustand_senden,EG_Heizaktor_11010_EG_EingangFlurWC_FBH_manuelle_Sollwertverschiebung_2_Byte,EG_Heizaktor_11010_EG_Eingang_Flur_WC_FBH_Sollwert_vorgeben,EG_Eingang_Flur_WC_Temperaturwert_empfangen,EG_Heizaktor_11010_EG_FBH_zentral_HeizenKuhlen_setzen,EG_Heizaktor_11010_EG_KucheEssen_FBH_Sollwert_vorgeben,EG_KucheEssen_FBH_Temperaturwert_empfangen,EG_Heizaktor_11010_EG_KucheEssen_aktueller_Sollwert_senden,EG_Heizaktor_11010_EG_KucheEssen_manuelle_Sollwertverschiebung_2_Byte,EG_Heizaktor_11010_EG_KucheWohnen_FBH_Diagnose_Status,EG_Heizaktor_11010_EG_KucheWohnen_FBH_Ventilzustand_senden,EG_Heizaktor_11010_EG_WohnenEssen_Temperaturwert_vorgeben,EG_Heizaktor_11010_EG_WohnenEssen_aktuelle_Temperatur,EG_Heizaktor_11010_EG_Wohnzimmer_FBH_Sollwert_vorgeben,EG_Heizaktor_11010_EG_Wohnzimmer_FBH_Stellwert_Heizen_Status_senden,EG_Wohnzimmer_FBH_Temperaturwert_empfangen,EG_Heizaktor_11010_EG_Wohnzimmer_FBH_Ventilzustand,EG_Heizaktor_11010_EG_Wohnzimmer_FBH_aktueller_Sollwert_senden,EG_Heizaktor_11010_EG_eingangFlurWC_FBH_aktueller_Sollwert_senden,EG_Heizaktor_11010_Eg_Wohnzimmer_FBH_aktuelle_Sollwertverschiebung_2_Byte,EG_Rollos_18_EG_Arbeitszimmer_Jalousie,EG_Rollos_18_EG_Arbeitszimmer_Lamellen,EG_Rollos_18_EG_Wohnzimmer_Balkon_Festelement_Lamellen,EG_Wohnzimmer_Jalousien_Lammellen_Eckfenster_Gesamt,EG_Rollos_18_EG_Wohnzimmer_Oberlicht_Mitte,EG_Rollos_18_EG_Wohnzimmer_Oberlicht_Mitte_Lamellen,EG_Rollos_18_EG_Wohnzimmer_Oberlicht_Seite_Balkon,EG_Rollos_18_EG_Wohnzimmer_Oberlicht_Seite_Balkon_Lamellen,EG_Rollos_18_EG_Wohnzimmer_Oberlichter_Lamellen,EG_Rollos_18_EG_Wohnzimmer_Oberlichter_komplett,EG_Rollos_18_EG_Wohnzimmer_Rolladen_Eckfenster_gesamt,EG_Rollos_18_EG_Wohnzimmer_Schiebetur_Festelement_Jalousie,EG_Rollos_18_TRH_Jalousien,EG_Rollos_912_11016_EG_Bad_Fenster_Lamellen,EG_Rollos_912_11016_EG_Bad_Fenster_Rolladen,EG_Rollos_912_11016_EG_Kuche_Fenster_Lamellen,EG_Rollos_912_11016_EG_Kuche_Fenster_Rolladen,EG_Rollos_912_11016_EG_Wohnzimmer_Balkontur_gross_Schiebeelement_Rolladen,EG_Rollos_912_11016_EG_Wohnzimmer_Schiebetur_Lamellen,EG_Rollos_912_11016_EG_Wohnzimmer_Terassentur_Lamellen,EG_Rollos_912_11016_EG_Wohnzimmer_Terassentur_Rolladen,EG_Rollos_912_11016_Rolladen_Tal,EG_Schaltaktor_11020_Aussen_Abfahrt_Treppenlicht_schalten,EG_Schaltaktor_11020_EG_Flur_Treppenlichtfunktion,EG_Schaltaktor_11020_EG_Speis_Licht,EG_Schaltaktor_11020_EG_Turaffner,EG_Schaltaktor_11020_EG_Wohnzimmer_Fernseher_Steckdosen,EG_Schaltaktor_11020_Garage_Licht_linksrechts,EG_Schaltaktor_11020_Garagentor_Offner,EG_Schaltaktor_11020_Licht_Outdoorkitchen,EG_Schaltaktor_DG_Licht,EG_Schaltaktor_EG_Arbeitszimmer_Steckdosen,EG_Schaltaktor_EG_Bad_Tur_Lamellen,EG_Schaltaktor_EG_Bad_Tur_Rolladen,EG_Schaltaktor_EG_Esszimmer_Licht,EG_Schaltaktor_EG_Kuche_Fenster_Licht,EG_Schaltaktor_EG_Kuche_Schranke_Licht,EG_Schaltaktor_EG_Wohnzimmer_Licht,EG_Wohnzimmer_Oberlichter_Lamellen,EG_Wohnzimmer_Tal_Lamellen,Erdkeller_Binareingang_Erdkeller_2_Reed_Fenster_links,Erdkeller_Binareingang_Erdkeller_2_Reed_Fenster_rechts,Erdkeller_Binareingang_Erdkeller_BWM_Gartengerate,Erdkeller_Binareingang_Erdkeller_BWM_Raum2_Nr_2,Erdkeller_Binareingang_Erdkeller_BWM_Raum_1,Erdkeller_Binareingang_Erdkeller_BWM_Raum_2_Nr_1,Erdkeller_Binareingang_Erdkeller_BWM_Treppe_oben,Erdkeller_Binareingang_Erdkeller_BWM_Treppe_unten,Erdkeller_Binareingang_Erdkeller_Reed_Werkstatt_Fenster_rechts,Erdkeller_Binareingang_Erdkeller_Werkstatt_Reed_Fenster_links,Gira_X1,Group_EG_Wohnzimmer_Raffstores_Tal,HTTP_URL_Thing_KG_Schlafen_Bad_ONOFF_KG_SchlafenBad_OnOff,KG_Abstellraum_Treppenlichtfunktion,KG_Bad_Licht_Spiegel,KG_Flur_LIcht,KG_Flur_Licht,KG_HWR_Licht,KG_Kind_Raum_Licht,KG_Kind_Steckdosen,KG_Kuche_Licht,KG_Licht_Schlafen,KG_Schlafzimmer_Steckdosen,KG_Technikraum_Licht,KG_Wohnen_Licht,KG_Wohnen_Steckdosen,Umwalzpumpe_Warmwasser_3_Minuten,KG_AMS_041602_Schaltaktor_mit_Strommessung_KG_HWR_Bugeleisen,KG_AMS_041602_Schaltaktor_mit_Strommessung_KG_HWR_Bugeleisen_Leistungswert_in_KW,KG_AMS_041602_Schaltaktor_mit_Strommessung_KG_HWR_Bugeleisen_theoretische_KWH,KG_AMS_041602_Schaltaktor_mit_Strommessung_KG_HWR_Licht,KG_AMS_041602_Schaltaktor_mit_Strommessung_KG_Licht_TRH,KG_Binaraktor_110140_KG_Abstellraum_BWM,KG_Binaraktor_110140_KG_Flur_hinten_bei_Wohnzimmer_BWM,KG_Binaraktor_110140_KG_Gang_vor_Abstellraum_BWM,KG_Binaraktor_110140_KG_TRH_BWM,KG_Jalousieaktor_KG_Bad_Rollo,KG_Jalousieaktor_KG_Bad_Rollo_Szene,KG_Jalousieaktor_KG_Kind_Rollo,KG_Jalousieaktor_KG_Kind_Rollo_Szene,KG_Jalousieaktor_KG_Schlafen_Rollo,KG_Jalousieaktor_KG_Schlafen_Rollo_Szene,KG_Jalousieaktor_KG_Wohnen_Rollo,KNX_Gerat_Erdkeller_Werkstatt_BWM,KNX_Wetterstation_Helligkeitswert_links,KNX_Wetterstation_Helligkeitswert_vorne,Hell_6_5_1,Dunkel_6_5_0,KNX_Wetterstation_Wetterstation_Helligkeitswert_max,KNX_Wetterstation_Wetterstation_Helligkeitswert_rechts,ONVIF_IP_Camera_Reolink_Garage,ONVIF_IP_Camera_Reolink_Garage_Cell_Motion_Alarm,ONVIF_IP_Camera_Reolink_Garage_MJPEG_URL,ONVIF_IP_Camera_Reolink_Garage_Motion_Alarm,Aussenlicht_Poolseite_schalten_Kanal_F,Erdkeller_1_Treppenlicht_Kanal_A,Erdkeller_2_Licht_schalten_Kanal_B,Erdkeller_2_Treppenlicht_Kanal_B,Erdkeller_Gartengerate_Licht_schalten,Erdkeller_Gartengerate_Treppenlicht_Kanal_D,Erdkeller_Licht_Schalten_Kanal_A,Erdkeller_TRH_Licht_Kanal_C,Erdkeller_Werkstatt_Licht_schalten_Kanal_E,Erdkeller_Werkstatt_Treppenlicht_Kanal_E,Pool_Licht_Schalten_Kanal_G,Universalaktor_EG_EGBueroSchreibtischLicht,Universalaktor_EG_Licht_Speis,Webhook_thing_Last_request,Webhook_thing_doorbird_label,WlanThermo_Mini_V2_Nano_V3_Link_V1,WlanThermo_Mini_V2_Nano_V3_Link_V1_Batterieladung,WlanThermo_Mini_V2_Nano_V3_Link_V1_Channel2_Alarm_Openhab_High,WlanThermo_Mini_V2_Nano_V3_Link_V1_Channel2_Alarm_Openhab_Low,WlanThermo_Mini_V2_Nano_V3_Link_V1_Channel2_Name,WlanThermo_Mini_V2_Nano_V3_Link_V1_Channel2_Temp,WlanThermo_Mini_V2_Nano_V3_Link_V1_Current_Temperature,WlanThermo_Mini_V2_Nano_V3_Link_V1_High_Temperature_Alarm,WlanThermo_Mini_V2_Nano_V3_Link_V1_Low_Temperature_Alarm,WlanThermo_Mini_V2_Nano_V3_Link_V1_Name,WlanThermo_Mini_V2_Nano_V3_Link_V1_Signalstarke:
So the list of Items and the strategies are on separate lines. I don’t know if that’s supported. All the docs and examples show them on the same line.
I made a 1-liner with the same result.
