Item= string or switch on Text label statement in sitemap
  • Hi,
    I can use sitemap statement like
    Text label=“SE inverter [%.1f kW]” icon=“solarplant” item=P_reduced visibility=[SE_flag == ON]
    if P_reduced is an Number.
I constructed a Summary string virtual item with value e.g. “100%, 25kW, OK” and wish him placed as Item=Summary in above Text label statement.
Result is an Err value. Is this in OH 2.5.12 possible please ?
Thanks.
RPi4, raspbian bulleseye 32bit
Openhab 2.5.12
Yes.
You cannot format a String using laberl “SE inverter [%.1f kW]”
You’ll need to use %s for strings
Thanks, before it was only Power Number in kW - after change to %s it’s correct.
