Item value not showing up in basicUI but showing in paperUI
  • Platform information:
    • Hardware: Raspberry PI 4 4GB
    • OS: buster
    • Java Runtime Environment: which java platform is used and what version
    • openHAB version: openHABian 2.5 11-1
  • Issue of the topic: item value not showing up in BasicUI but showing up in paperUI
    • Items configuration
      Number OU_Porch_Temperature “Temperature” (OU_Porch, gTemperature) [“Temperature”] {channel=“mqtt:topic:5db0844c:temperature”}
also “c” after the value isnt showing up in the paper or basic UI
this is a BMP280 sensor , humidity and pressure you can see
i have more BMP280 sensors and all of them i can see the basicUI ok and they are using the same item configuration
this has been working before
Change the text in your item file to
Number OU_Porch_Temperature "Porch temperature [%.1f %unit%]
This will add the temperature
How come the other sensors are ok?
Will try that later ,many thanks
How far do I alter the sitemap to include this?
In your sitemap your add the item as follows
Default item=OU_Porch_Temperature
Without any label. (if you add a label it will overwrite your label from the .item file)
In general, “you get what you ask for”.
So if an OH2 Item does not have a [state presentation] data embedded in its label string, you get no display.
Some binding channels can “suggest” a [state presentation] when linked to an Item, a default. So then you do get to see something even if you didn’t ask.
Understanding “some show up and some don’t” becomes a question of understanding the detail of what channels you linked them to. In OH2 it’s mostly zwave making “suggestions”.
You can override what the Item thinks, by giving a [state presentation] in the label= string of a sitemap widget.
To complete the story, you can deliberately suppress state display with an empty [] presentation - you might do that for a switch widget, to stop ON/OFF displaying alongside the slider.
