Hi guys,
This looks like a bug to me, but a guru opinion would be nice before filing a bug report.
I am having this strange problem that values sent from ESP via mqtt are sometimes parsed and sometimes not.
For each ESP node I have three OH items: VCC, temperature and humidity.
Number Spalnica_temp "Spalnica [%.1f °C]" <temperature> (gTemp) {mqtt="<[mosquitto:/hooks/devices/21/SensorData/Temperature:state:default]"}
Number Spalnica_hum "Spalnica [%.1f %% RH]" <humidity> (gTemp) {mqtt="<[mosquitto:/hooks/devices/21/SensorData/Humidity:state:default]"}
Number Spalnica_VCC "Spalnica [%.1f V]" <voltage> (gMonitoring) {mqtt="<[mosquitto:/hooks/devices/21/SensorData/VCC:state:default]"}
Number Tine_temp "Tinetova soba [%.1f °C]" <temperature> (gTemp) {mqtt="<[mosquitto:/hooks/devices/20/SensorData/Temperature:state:default]"}
Number Tine_hum "Tinetova soba [%.1f %% RH]" <humidity> (gTemp) {mqtt="<[mosquitto:/hooks/devices/20/SensorData/Humidity:state:default]"}
Number Tine_VCC "Tinetova soba [%.1f V]" <voltage> (gMonitoring) {mqtt="<[mosquitto:/hooks/devices/20/SensorData/VCC:state:default]"}
Data is sent every 5 minutes. Debug shows that values are correctly received through MQTT, but somehow OH does not parse them and update the values. I noticed this when updated to OH 2.2 snapshot, however it might be happening before,
because I didn’t have persistence graphs and without those, you don’t really notice it. The values on the panels are there, they are just updated rarely…
Below there are two logs: in the first VCC is not parsed, but temperature and humidity are. Next packet received (5 minutes later) only parsed humidity.
I disabled persistence, but it didn’t help. Can I try something else? Should I try another version? Thanx for help!
22:13:39.263 [DEBUG] [.mqttv3.internal.wire.MqttInputStream] - null: Automatic Reconnect Successful: PUBLISH qos:0 retained:false dup:false topic:"/hooks/devices/21/SensorData/VCC" payload:[hex:332e3338 utf8:"3.38" length:4]
22:13:39.267 [DEBUG] [ho.client.mqttv3.internal.ClientState] - openHab-Id: received key=0 message=PUBLISH qos:0 retained:false dup:false topic:"/hooks/devices/21/SensorData/VCC" payload:[hex:332e3338 utf8:"3.38" length:4]
22:13:39.270 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: new msg avail, notify workAvailable
22:13:39.273 [DEBUG] [.client.mqttv3.internal.CommsReceiver] - openHab-Id: network read message
22:13:39.274 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: call messageArrived key=0 topic=/hooks/devices/21/SensorData/VCC
22:13:39.279 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: notify spaceAvailable
22:13:39.283 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: wait for workAvailable
22:13:40.302 [DEBUG] [ho.client.mqttv3.internal.ClientState] - openHab-Id: received bytes count=1
22:13:40.315 [DEBUG] [ho.client.mqttv3.internal.ClientState] - openHab-Id: received bytes count=46
22:13:40.318 [DEBUG] [.mqttv3.internal.wire.MqttInputStream] - null: Automatic Reconnect Successful: PUBLISH qos:0 retained:false dup:false topic:"/hooks/devices/21/SensorData/Temperature" payload:[hex:32332e32 utf8:"23.2" length:4]
22:13:40.322 [DEBUG] [ho.client.mqttv3.internal.ClientState] - openHab-Id: received key=0 message=PUBLISH qos:0 retained:false dup:false topic:"/hooks/devices/21/SensorData/Temperature" payload:[hex:32332e32 utf8:"23.2" length:4]
22:13:40.326 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: new msg avail, notify workAvailable
22:13:40.329 [DEBUG] [.client.mqttv3.internal.CommsReceiver] - openHab-Id: network read message
22:13:40.330 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: call messageArrived key=0 topic=/hooks/devices/21/SensorData/Temperature
22:13:40.333 [DEBUG] [ho.client.mqttv3.internal.ClientState] - openHab-Id: received bytes count=1
22:13:40.337 [DEBUG] [ho.client.mqttv3.internal.ClientState] - openHab-Id: received bytes count=43
22:13:40.339 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: notify spaceAvailable
22:13:40.342 [DEBUG] [.mqttv3.internal.wire.MqttInputStream] - null: Automatic Reconnect Successful: PUBLISH qos:0 retained:false dup:false topic:"/hooks/devices/21/SensorData/Humidity" payload:[hex:35392e36 utf8:"59.6" length:4]
22:13:40.343 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: wait for workAvailable
22:13:40.346 [DEBUG] [ho.client.mqttv3.internal.ClientState] - openHab-Id: received key=0 message=PUBLISH qos:0 retained:false dup:false topic:"/hooks/devices/21/SensorData/Humidity" payload:[hex:35392e36 utf8:"59.6" length:4]
22:13:40.349 [INFO ] [smarthome.event.ItemStateChangedEvent] - Spalnica_temp changed from 23.1 to 23.2
22:13:40.350 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: new msg avail, notify workAvailable
22:13:40.354 [DEBUG] [.client.mqttv3.internal.CommsReceiver] - openHab-Id: network read message
22:13:40.354 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: call messageArrived key=0 topic=/hooks/devices/21/SensorData/Humidity
22:13:40.362 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: notify spaceAvailable
22:13:40.365 [INFO ] [smarthome.event.ItemStateChangedEvent] - Spalnica_hum changed from 59.7 to 59.6
22:13:40.366 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: wait for workAvailable
22:13:41.669 [DEBUG] [org.quartz.core.QuartzSchedulerThread] - batch acquisition of 0 triggers
22:14:08.595 [DEBUG] [org.quartz.core.QuartzSchedulerThread] - batch acquisition of 0 triggers
22:14:34.307 [DEBUG] [org.quartz.core.QuartzSchedulerThread] - batch acquisition of 0 triggers
22:17:36.421 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: notify spaceAvailable
22:17:36.424 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: wait for workAvailable
22:17:57.641 [DEBUG] [org.quartz.core.QuartzSchedulerThread] - batch acquisition of 0 triggers
22:18:24.909 [DEBUG] [org.quartz.core.QuartzSchedulerThread] - batch acquisition of 0 triggers
22:18:29.091 [DEBUG] [ho.client.mqttv3.internal.ClientState] - openHab-Id: received bytes count=1
22:18:29.094 [DEBUG] [ho.client.mqttv3.internal.ClientState] - openHab-Id: received bytes count=38
22:18:29.098 [DEBUG] [.mqttv3.internal.wire.MqttInputStream] - null: Automatic Reconnect Successful: PUBLISH qos:0 retained:false dup:false topic:"/hooks/devices/21/SensorData/VCC" payload:[hex:332e3338 utf8:"3.38" length:4]
22:18:29.101 [DEBUG] [ho.client.mqttv3.internal.ClientState] - openHab-Id: received key=0 message=PUBLISH qos:0 retained:false dup:false topic:"/hooks/devices/21/SensorData/VCC" payload:[hex:332e3338 utf8:"3.38" length:4]
22:18:29.104 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: new msg avail, notify workAvailable
22:18:29.108 [DEBUG] [.client.mqttv3.internal.CommsReceiver] - openHab-Id: network read message
22:18:29.108 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: call messageArrived key=0 topic=/hooks/devices/21/SensorData/VCC
22:18:29.114 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: notify spaceAvailable
22:18:29.118 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: wait for workAvailable
22:18:30.132 [DEBUG] [ho.client.mqttv3.internal.ClientState] - openHab-Id: received bytes count=1
22:18:30.136 [DEBUG] [ho.client.mqttv3.internal.ClientState] - openHab-Id: received bytes count=46
22:18:30.140 [DEBUG] [.mqttv3.internal.wire.MqttInputStream] - null: Automatic Reconnect Successful: PUBLISH qos:0 retained:false dup:false topic:"/hooks/devices/21/SensorData/Temperature" payload:[hex:32332e32 utf8:"23.2" length:4]
22:18:30.144 [DEBUG] [ho.client.mqttv3.internal.ClientState] - openHab-Id: received key=0 message=PUBLISH qos:0 retained:false dup:false topic:"/hooks/devices/21/SensorData/Temperature" payload:[hex:32332e32 utf8:"23.2" length:4]
22:18:30.147 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: new msg avail, notify workAvailable
22:18:30.150 [DEBUG] [.client.mqttv3.internal.CommsReceiver] - openHab-Id: network read message
22:18:30.151 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: call messageArrived key=0 topic=/hooks/devices/21/SensorData/Temperature
22:18:30.154 [DEBUG] [ho.client.mqttv3.internal.ClientState] - openHab-Id: received bytes count=1
22:18:30.158 [DEBUG] [ho.client.mqttv3.internal.ClientState] - openHab-Id: received bytes count=43
22:18:30.161 [DEBUG] [.mqttv3.internal.wire.MqttInputStream] - null: Automatic Reconnect Successful: PUBLISH qos:0 retained:false dup:false topic:"/hooks/devices/21/SensorData/Humidity" payload:[hex:36312e31 utf8:"61.1" length:4]
22:18:30.162 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: notify spaceAvailable
22:18:30.165 [DEBUG] [ho.client.mqttv3.internal.ClientState] - openHab-Id: received key=0 message=PUBLISH qos:0 retained:false dup:false topic:"/hooks/devices/21/SensorData/Humidity" payload:[hex:36312e31 utf8:"61.1" length:4]
22:18:30.170 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: wait for workAvailable
22:18:30.175 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: new msg avail, notify workAvailable
22:18:30.178 [DEBUG] [.client.mqttv3.internal.CommsReceiver] - openHab-Id: network read message
22:18:30.179 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: call messageArrived key=0 topic=/hooks/devices/21/SensorData/Humidity
22:18:30.185 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: notify spaceAvailable
22:18:30.189 [INFO ] [smarthome.event.ItemStateChangedEvent] - Spalnica_hum changed from 59.6 to 61.1
22:18:30.190 [DEBUG] [.client.mqttv3.internal.CommsCallback] - openHab-Id: wait for workAvailable
22:18:36.347 [DEBUG] [se.paho.client.mqttv3.TimerPingSender] - null: Check schedule at 1,505,337,516,346
22:18:36.350 [DEBUG] [ho.client.mqttv3.internal.ClientState] - openHab-Id: checkForActivity entered
22:18:36.354 [DEBUG] [ho.client.mqttv3.internal.ClientState] - openHab-Id: ping needed. keepAlive=60,000 lastOutboundActivity=1,505,337,456,352 lastInboundActivity=1,505,337,510,164
22:18:36.358 [DEBUG] [lient.mqttv3.internal.CommsTokenStore] - openHab-Id: key=Ping message=PINGREQ
22:18:36.361 [DEBUG] [lient.mqttv3.internal.CommsTokenStore] - openHab-Id: key=Ping token=org.eclipse.paho.client.mqttv3.MqttToken@1afb06b
