Not sure about the values and if I need to invert yet but I get an error telling me:
Received a QuantityType '4 %' with unit, but the boundaries are defined as a plain number without units (lower=0, upper=0), please consider adding units to them.
This does not make sense for me at all. I use OH 3.4.1 with shelly binding 3.4.2 beta manually installed. Documentation I checked also include examples with units.
You might need to double the percent signs to %% same as you would for a label. if that doesn’t work, I don’t know what you’d need to do. I don’t use .items files anymore.
I changed back from Shelly beta binding 3.4.2 to stable 3.4.1 => maybe this caused the error which does not show up again at all at any time now.
My issue now is the hysteresis does not behave as expected.
I have a channel I also use testwise to visualize “ShellyEGGaesteWCRolloRollerposInverted2”.
This value is between 0 and 100 without units according to the log. I want to map everything from 0 (totally closed) to 99 (almost complexly opened) to an switch with state ON and if the value is 100 to switch state OFF.
Therefor I expect [profile=“system:hysteresis”, lower=100] using the same channel as the Dimmer item above is the right approach. Unfortunately now if the value is 0 it is ON and else OFF. Inverted does not do anything by the way.
