Hi all,
hope somone of you can help me.
- Platform information:
- Hardware: Core i5 / 64 bit / 16 GB RAM / 256 GB SSD
- OS: Win 7 Enterprise 64 bit
- Java Runtime Environment: JDK 1.8.0_151 32 bit
- openHAB version: 2.2.0 Build 1075
Start configure OH2 with KNX Binding on Windows 7 machine
First I thought it was an issue with 2.1 stable build and so I downloaded the latest snapshot 2.2.0 Build 1075 for testing.
I’m using a very basic setup for the first steps but still get errors in log that items are not registered.
KNX bind seems to be ok so i didn’t post the config now.
Any hints what’s wrong with my setup?
knx.items
Switch myItem "Myitem" <kitchen> {knx="1/1/2"}
demo.sitemap
sitemap demo label="Mein Stadthaus" {
Frame label="Items" {
Switch item=myItem
openhab.log
2017-11-10 12:56:16.690 [WARN ] [basic.internal.render.SwitchRenderer] - Cannot determine item type of 'myItem'
org.eclipse.smarthome.core.items.ItemNotFoundException: Item 'myItem' could not be found in the item registry
at org.eclipse.smarthome.core.internal.items.ItemRegistryImpl.getItem(ItemRegistryImpl.java:61) [98:org.eclipse.smarthome.core:0.9.0.201710240931]
at org.eclipse.smarthome.ui.internal.items.ItemUIRegistryImpl.getItem(ItemUIRegistryImpl.java:716) [137:org.eclipse.smarthome.ui:0.9.0.201710240931]
at org.eclipse.smarthome.ui.basic.internal.render.SwitchRenderer.renderWidget(SwitchRenderer.java:50) [176:org.eclipse.smarthome.ui.basic:0.9.0.201710240931]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.renderWidget(PageRenderer.java:167) [176:org.eclipse.smarthome.ui.basic:0.9.0.201710240931]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:132) [176:org.eclipse.smarthome.ui.basic:0.9.0.201710240931]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:153) [176:org.eclipse.smarthome.ui.basic:0.9.0.201710240931]
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processPage(PageRenderer.java:95) [176:org.eclipse.smarthome.ui.basic:0.9.0.201710240931]
at org.eclipse.smarthome.ui.basic.internal.servlet.WebAppServlet.service(WebAppServlet.java:152) [176:org.eclipse.smarthome.ui.basic:0.9.0.201710240931]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:845) [85:org.eclipse.jetty.servlet:9.3.14.v20161028]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [85:org.eclipse.jetty.servlet:9.3.14.v20161028]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [171:org.ops4j.pax.web.pax-web-jetty:6.0.6]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.3.14.v20161028]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [171:org.ops4j.pax.web.pax-web-jetty:6.0.6]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [85:org.eclipse.jetty.servlet:9.3.14.v20161028]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [171:org.ops4j.pax.web.pax-web-jetty:6.0.6]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:320) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273) [76:org.eclipse.jetty.io:9.3.14.v20161028]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95) [76:org.eclipse.jetty.io:9.3.14.v20161028]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [76:org.eclipse.jetty.io:9.3.14.v20161028]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [87:org.eclipse.jetty.util:9.3.14.v20161028]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [87:org.eclipse.jetty.util:9.3.14.v20161028]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [87:org.eclipse.jetty.util:9.3.14.v20161028]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [87:org.eclipse.jetty.util:9.3.14.v20161028]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [87:org.eclipse.jetty.util:9.3.14.v20161028]
2017-11-10 12:56:16.696 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'myItem' for widget org.eclipse.smarthome.model.sitemap.Switch
2017-11-10 12:56:16.697 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2017-11-10 12:56:16.698 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'myItem' for widget org.eclipse.smarthome.model.sitemap.Switch
2017-11-10 12:56:16.699 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'myItem' for widget org.eclipse.smarthome.model.sitemap.Switch
