Hey there,
I was just starting to customize my sitemap and I clicked on some of the groups and sub-groups I had.
And it showed me my solar panels which I don’t have configured in the sitemap file, only in the items file.
I defined a group called garage where all the data from the solar panels are in. So in my items file the solar panel ONLY is in a group called garage.
On my sitemap I also have a sub-group called garage and that’s where they are shown on the sitemap, but the solar panel is not defined on the sitemap and does not even appears once in the sitemap file.
I changed the group of the panels in the items file and they disappeared. (Well if not i would’ve a much bigger problem.)
But my question just is, is that normal like is that supposed to happen? Because I thought only items defined in the sitemap file will appear later in the sitemap. Since when is it possible to define items on the sitemap via the items file?
I’m just wondering maybe you can help me out. Thanks!
