OK. I found the problem with the growing… my fault… a typo ‘stragegy’ must be ‘strategy’ for some item.
Let me clean up first and see if some items still show up like described in the topic.
Sorry for this mistake.
I still found the following errors when editing the .persist files in VSCode, how the first error came about I can’t remember exactly, but in any case I opened the .persist file at that time and copied the content …
2023-04-27 20:16:17.995 [ERROR] [xt.ide.server.concurrent.ReadRequest] - Error during request:
java.lang.RuntimeException: Cannot create a resource for 'virtual://openhab.org/persistence/strategy.global'; a registered resource factory is needed
at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:263) ~[?:?]
at org.eclipse.xtext.ide.server.ProjectManager.getResource(ProjectManager.java:169) ~[?:?]
at org.eclipse.xtext.ide.server.WorkspaceManager.doRead(WorkspaceManager.java:436) ~[?:?]
at org.eclipse.xtext.ide.server.findReferences.WorkspaceResourceAccess.readOnly(WorkspaceResourceAccess.java:36) ~[?:?]
at org.eclipse.xtext.ide.server.symbol.DocumentSymbolService.doRead(DocumentSymbolService.java:332) ~[?:?]
at org.eclipse.xtext.ide.server.symbol.DocumentSymbolService.getDefinitions(DocumentSymbolService.java:112) ~[?:?]
at org.eclipse.xtext.ide.server.symbol.DocumentSymbolService.getDefinitions(DocumentSymbolService.java:99) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$definition$25(LanguageServerImpl.java:607) ~[?:?]
at org.eclipse.xtext.ide.server.WorkspaceManager.doRead(WorkspaceManager.java:438) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.definition(LanguageServerImpl.java:606) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.definition(LanguageServerImpl.java:594) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$definition$24(LanguageServerImpl.java:585) ~[?:?]
at org.eclipse.xtext.ide.server.concurrent.ReadRequest.lambda$doRun$0(ReadRequest.java:66) ~[?:?]
2023-04-27 20:16:19.074 [ERROR] [xt.ide.server.concurrent.ReadRequest] - Error during request:
2023-04-27 20:17:35.987 [ERROR] [t.ide.server.concurrent.WriteRequest] - Error during request:
java.util.concurrent.CompletionException: java.lang.RuntimeException: Cannot create a resource for 'virtual://openhab.org/persistence/strategy.global'; a registered resource factory is needed
at java.util.concurrent.CompletableFuture.encodeThrowable(CompletableFuture.java:331) ~[?:?]
at java.util.concurrent.CompletableFuture.andTree(CompletableFuture.java:1452) ~[?:?]
at java.util.concurrent.CompletableFuture.andTree(CompletableFuture.java:1442) ~[?:?]
at java.util.concurrent.CompletableFuture.andTree(CompletableFuture.java:1444) ~[?:?]
at java.util.concurrent.CompletableFuture.allOf(CompletableFuture.java:2337) ~[?:?]
at org.eclipse.xtext.ide.server.concurrent.RequestManager.cancel(RequestManager.java:114) ~[?:?]
at org.eclipse.xtext.ide.server.concurrent.RequestManager.runWrite(RequestManager.java:80) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.runBuildable(LanguageServerImpl.java:457) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.didOpen(LanguageServerImpl.java:383) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.services.GenericEndpoint.lambda$null$0(GenericEndpoint.java:65) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.services.GenericEndpoint.notify(GenericEndpoint.java:152) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.RemoteEndpoint.handleNotification(RemoteEndpoint.java:220) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.RemoteEndpoint.consume(RemoteEndpoint.java:187) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.json.StreamMessageProducer.handleMessage(StreamMessageProducer.java:194) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.json.StreamMessageProducer.listen(StreamMessageProducer.java:94) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.json.ConcurrentMessageProcessor.run(ConcurrentMessageProcessor.java:113) ~[?:?]
Caused by: java.lang.RuntimeException: Cannot create a resource for 'virtual://openhab.org/persistence/strategy.global'; a registered resource factory is needed
... 5 more
2023-04-28 09:48:48.231 [ERROR] [st.antlr.ContentAssistContextFactory] - java.lang.RuntimeException: java.lang.NullPointerException
java.util.concurrent.ExecutionException: java.lang.RuntimeException: java.lang.NullPointerException
at java.util.concurrent.FutureTask.report(FutureTask.java:122) ~[?:?]
at java.util.concurrent.FutureTask.get(FutureTask.java:191) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.doCreateContexts(ContentAssistContextFactory.java:181) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.create(ContentAssistContextFactory.java:131) ~[?:?]
at org.eclipse.xtext.ide.server.contentassist.ContentAssistService.createProposals(ContentAssistService.java:104) ~[?:?]
at org.eclipse.xtext.ide.server.contentassist.ContentAssistService.createCompletionList(ContentAssistService.java:78) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$completion$23(LanguageServerImpl.java:555) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.completion(LanguageServerImpl.java:554) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$completion$22(LanguageServerImpl.java:540) ~[?:?]
Caused by: java.lang.RuntimeException: java.lang.NullPointerException
at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:246) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:237) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:232) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.AbstractContentAssistParser.getFollowElements(AbstractContentAssistParser.java:49) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.AbstractContentAssistParser.getFollowElements(AbstractContentAssistParser.java:27) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:264) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.handleLastCompleteNodeIsAtEndOfDatatypeNode(ContentAssistContextFactory.java:230) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$2.call(ContentAssistContextFactory.java:161) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$2.call(ContentAssistContextFactory.java:158) ~[?:?]
... 4 more
Caused by: java.lang.NullPointerException
at java.util.Objects.requireNonNull(Objects.java:221) ~[?:?]
at java.lang.Class.getMethod(Class.java:2101) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:169) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:242) ~[?:?]
... 4 more
2023-04-28 09:48:48.236 [ERROR] [st.antlr.ContentAssistContextFactory] - java.lang.RuntimeException: java.lang.NullPointerException
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.createContextsForLastCompleteNode(ContentAssistContextFactory.java:299) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.handleLastCompleteNodeIsPartOfLookahead(ContentAssistContextFactory.java:220) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$3.call(ContentAssistContextFactory.java:172) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$3.call(ContentAssistContextFactory.java:169) ~[?:?]
... 4 more
... 4 more
Please be aware that LSP is used for every single character that is typed, so it’s normal to get many errors while typing.
Another question is, if it would be better to wait at least until end of a word
If the .persist
file is invalid, the default strategy is applied. This explains why the database is filling up quickly, because every change of every item is persisted in that case.
