I have the following items configuration:
Group gPowerHeads
Group gOutlets
Number Temperature <temperature> {mysensors="5;1;V_TEMP"}
Number dBattery {mysensors="5;255;I_BATTERY_LEVEL"}
Switch Outlet1_1 "Display Light" <light> {mysensors="4;1;V_STATUS"}
Switch Outlet1_2 "Left Powerhead" <light> (gPowerHeads,gOutlets) {mysensors="4;2;V_STATUS"}
Switch Outlet1_3 "Right Powerhead" <light> (gPowerHeads,gOutlets) {mysensors="4;3;V_STATUS"}
Switch Outlet1_4 "Empty" <light> (gPowerHeads,gOutlets) {mysensors="4;4;V_STATUS"}
Switch Outlet2-2 (gOutlets) {mysensors="6;1;V_STATUS"}
Switch Outlet2-2 (gOutlets) {mysensors="6;2;V_STATUS"}
Switch Outlet2-3 (gOutlets) {mysensors="6;3;V_STATUS"}
Switch Outlet2-4 (gOutlets) {mysensors="6;4;V_STATUS"}
String Sunrise "Bermuda sunrise is at [%s]"
String Sunset "Bermuda sunset is at [%s]"
Switch test
Number sTemperature "Sump Temperature" {mysensors="3;2;V_VAR1"}
Switch sFloat1 "High Float" <light> (gPowerHeads) {mysensors="3;3;V_STATUS"}
Switch sFloat2 "Fill Float" <light> (gPowerHeads) {mysensors="3;4;V_STATUS"}
Switch sFloat3 "Low Float" <light> (gPowerHeads) {mysensors="3;5;V_STATUS"}
Number sBattery "Sump Battery" {mysensors="3;255;I_BATTERY_LEVEL"}
I have 6;1;V_STATUS defined but I’m still getting this message in the log:
2016-11-16 22:20:11.190 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "6;1;V_STATUS"
2016-11-16 22:20:11.193 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "6;2;V_STATUS"
2016-11-16 22:20:11.195 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "6;3;V_STATUS"
2016-11-16 22:20:11.198 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "6;4;V_STATUS"
Any ideas on why its not working?
