Hi, I’m new to openHAB and I really enjoy the technology, but I got some problems. When I try to control my things ( Philips hue Lamp) by updating his state with the method below, I can change the state of the Items but I can’t see NO CHANGES with my Light… Can you help me please to solve this problem ?
I could also use http PUT Request ( J Query-Ajax) but I found the Fetch API easier, like I said the Request succeded but why the light doesn’t change ?
16:52:08.071 [INFO ] [smarthome.event.ItemStateChangedEvent] - hue_0210_001788285fd9_10_color_temperature changed from 61 to 80
16:52:54.863 [INFO ] [smarthome.event.ItemStateChangedEvent] - hue_0210_001788285fd9_10_color_temperature changed from 80 to 10
16:54:01.183 [INFO ] [smarthome.event.ItemStateChangedEvent] - hue_0210_001788285fd9_10_color_temperature changed from 10 to 5
16:54:38.742 [INFO ] [smarthome.event.ItemStateChangedEvent] - hue_0210_001788285fd9_10_color_temperature changed from 5 to 90
The openHAB Runtime received the changes of the ItemState : - from 61 (%) to 80 (%)
- from 80 (%) to 10 (%)
- from 10 (%) to 5 (%) and so on
BUT my Philips Hue Lamp does NOT change ( It should change the light intensity)
this is what my logs are showing:
Thank you ei_Gelb_GeekKevin for your time and reply, I got it ! The Problem is, I was only sending a PUT Request ( what only update the state of my Item) BUT not sending a POST request
