I have trouble running the itests locally (commit 2127ac)
/src/openhab-master/git/openhab-addons $ mvn clean install -DwithResolver=true -pl :org.openhab.binding.modbus,:org.openhab.binding.modbus.tests
... SNIP ...
[INFO] --- bnd-maven-plugin:5.2.0:bnd-process (default) @ org.openhab.binding.modbus.tests ---
[INFO]
[INFO] --- maven-resources-plugin:3.0.2:testResources (default-testResources) @ org.openhab.binding.modbus.tests ---
[INFO] Using 'UTF-8' encoding to copy filtered resources.
[INFO] skip non existing resourceDirectory /home/salski/src/openhab-master/git/openhab-addons/itests/org.openhab.binding.modbus.tests/src/test/resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.1:testCompile (default-testCompile) @ org.openhab.binding.modbus.tests ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:3.0.0-M5:test (default-test) @ org.openhab.binding.modbus.tests ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:3.0.2:jar (default-jar) @ org.openhab.binding.modbus.tests ---
[INFO] Building jar: /home/salski/src/openhab-master/git/openhab-addons/itests/org.openhab.binding.modbus.tests/target/org.openhab.binding.modbus.tests-3.1.0-SNAPSHOT.jar
[INFO]
[INFO] --- bnd-indexer-maven-plugin:5.2.0:index (index) @ org.openhab.binding.modbus.tests ---
[INFO]
[INFO] --- bnd-indexer-maven-plugin:5.2.0:index (test-index) @ org.openhab.binding.modbus.tests ---
[INFO]
[INFO] --- bnd-resolver-maven-plugin:5.2.0:resolve (default) @ org.openhab.binding.modbus.tests ---
[ERROR] Resolution failed. Capabilities satisfying the following requirements could not be found:
[<<INITIAL>>]
β osgi.identity: (osgi.identity=org.openhab.binding.modbus.tests)
β [org.openhab.binding.modbus.tests version=3.1.0.202101290639]
β osgi.wiring.package: (&(osgi.wiring.package=org.junit.jupiter.api)(version>=5.7.0)(!(version>=6.0.0)))
The following requirements are optional:
[org.apache.felix.configadmin version=1.9.8]
β osgi.wiring.package: (&(osgi.wiring.package=org.osgi.service.coordinator)(version>=1.0.0)(!(version>=2.0.0)))
[junit-jupiter-api version=5.6.2]
β osgi.wiring.package: (osgi.wiring.package=kotlin.jvm.internal)
β osgi.wiring.package: (osgi.wiring.package=kotlin)
β osgi.wiring.package: (osgi.wiring.package=kotlin.collections)
β osgi.wiring.package: (osgi.wiring.package=kotlin.jvm.functions)
[org.eclipse.jetty.server version=9.4.20.v20190813]
β osgi.wiring.package: (&(osgi.wiring.package=org.eclipse.jetty.jmx)(version>=9.4.20)(!(version>=10.0.0)))
[ch.qos.logback.classic version=1.2.3]
β osgi.wiring.package: (&(osgi.wiring.package=org.codehaus.groovy.runtime.wrappers)(version>=2.4.0)(!(version>=3.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=org.codehaus.groovy.runtime.callsite)(version>=2.4.0)(!(version>=3.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=org.codehaus.groovy.control)(version>=2.4.0)(!(version>=3.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=javax.servlet.http)(version>=3.1.0)(!(version>=4.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=org.codehaus.groovy.runtime)(version>=2.4.0)(!(version>=3.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=javax.servlet)(version>=3.1.0)(!(version>=4.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=groovy.lang)(version>=2.4.0)(!(version>=3.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=org.codehaus.groovy.runtime.typehandling)(version>=2.4.0)(!(version>=3.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=org.codehaus.groovy.control.customizers)(version>=2.4.0)(!(version>=3.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=org.codehaus.groovy.transform)(version>=2.4.0)(!(version>=3.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=org.codehaus.groovy.reflection)(version>=2.4.0)(!(version>=3.0.0)))
[org.eclipse.jetty.servlet version=9.4.20.v20190813]
β osgi.wiring.package: (&(osgi.wiring.package=org.eclipse.jetty.util.annotation)(version>=9.4.20)(!(version>=10.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=org.eclipse.jetty.util.component)(version>=9.4.20)(!(version>=10.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=org.eclipse.jetty.util)(version>=9.4.20)(!(version>=10.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=org.eclipse.jetty.util.log)(version>=9.4.20)(!(version>=10.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=org.eclipse.jetty.util.resource)(version>=9.4.20)(!(version>=10.0.0)))
[org.openhab.core version=3.0.0.202012040254]
β osgi.service: (objectClass=org.openhab.core.scheduler.CronJob)
β osgi.service: (objectClass=org.openhab.core.auth.AuthenticationProvider)
β osgi.service: (objectClass=org.openhab.core.binding.BindingInfoProvider)
[org.apache.felix.gogo.runtime version=1.0.10]
β osgi.wiring.package: (&(osgi.wiring.package=org.osgi.service.event)(version>=1.3.0)(!(version>=2.0.0)))
[org.apache.geronimo.specs.geronimo-activation_1.1_spec version=1.1.0]
β osgi.wiring.package: (osgi.wiring.package=org.apache.geronimo.osgi.registry.api)
[org.apache.felix.scr version=2.1.10]
β osgi.wiring.package: (&(osgi.wiring.package=org.osgi.service.metatype)(version>=1.2.0)(!(version>=2.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=org.apache.felix.shell)(version>=1.0.0)(!(version>=1.1.0)))
β osgi.wiring.package: (&(osgi.wiring.package=org.apache.felix.service.command)(version>=1.0.0)(!(version>=2.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=org.osgi.service.cm)(version>=1.6.0)(!(version>=2.0.0)))
[org.openhab.core.config.core version=3.0.0.202012040258]
β osgi.service: (objectClass=org.openhab.core.i18n.TranslationProvider)
β osgi.service: (objectClass=org.openhab.core.config.core.status.ConfigStatusProvider)
β osgi.service: (objectClass=org.openhab.core.config.core.metadata.MetadataConfigDescriptionProvider)
β osgi.service: (objectClass=org.openhab.core.config.core.ConfigDescriptionAliasProvider)
[org.eclipse.jetty.http version=9.4.20.v20190813]
β osgi.extender: (osgi.extender=osgi.serviceloader.processor)
β osgi.extender: (osgi.extender=osgi.serviceloader.registrar)
[biz.aQute.tester.junit-platform version=5.1.2.202007211702]
β osgi.wiring.package: (&(osgi.wiring.package=org.junit)(version>=4.10.0)(!(version>=5.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=aQute.bnd.service)(version>=4.5.0)(!(version>=5.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=junit.framework)(version>=3.8.0)(!(version>=5.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=aQute.bnd.build)(version>=3.4.0)(!(version>=4.0.0)))
β osgi.extender: (&(osgi.extender=osgi.serviceloader.registrar)(version>=1.0.0)(!(version>=2.0.0)))
[org.eclipse.jetty.util version=9.4.20.v20190813]
β osgi.wiring.package: (&(osgi.wiring.package=org.slf4j)(version>=1.7.25)(!(version>=2.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=org.slf4j.spi)(version>=1.7.25)(!(version>=2.0.0)))
β osgi.serviceloader: (osgi.serviceloader=org.eclipse.jetty.util.security.CredentialProvider)
β osgi.wiring.package: (&(osgi.wiring.package=org.slf4j.helpers)(version>=1.7.25)(!(version>=2.0.0)))
[org.openhab.core.thing version=3.0.0.202012040259]
β osgi.service: (objectClass=org.openhab.core.thing.firmware.FirmwareProvider)
β osgi.service: (objectClass=org.openhab.core.thing.profiles.ProfileAdvisor)
β osgi.service: (objectClass=org.openhab.core.thing.binding.ThingTypeProvider)
β osgi.service: (objectClass=org.openhab.core.thing.profiles.ProfileFactory)
β osgi.service: (objectClass=org.openhab.core.thing.type.DynamicCommandDescriptionProvider)
β osgi.service: (objectClass=org.openhab.core.thing.type.DynamicStateDescriptionProvider)
β osgi.service: (objectClass=org.openhab.core.events.EventPublisher)
β osgi.service: (objectClass=org.openhab.core.thing.binding.firmware.FirmwareUpdateHandler)
β osgi.service: (objectClass=org.openhab.core.thing.binding.ThingHandlerFactory)
β osgi.service: (objectClass=org.openhab.core.thing.type.ChannelGroupTypeProvider)
[ch.qos.logback.core version=1.2.3]
β osgi.wiring.package: (osgi.wiring.package=org.codehaus.janino)
β osgi.wiring.package: (osgi.wiring.package=javax.mail.internet)
β osgi.wiring.package: (osgi.wiring.package=org.codehaus.commons.compiler)
β osgi.wiring.package: (&(osgi.wiring.package=org.fusesource.jansi)(version>=1.9.0)(!(version>=2.0.0)))
β osgi.wiring.package: (osgi.wiring.package=javax.mail)
[xstream version=1.4.13]
β osgi.wiring.package: (osgi.wiring.package=com.sun.xml.internal.stream)
β osgi.wiring.package: (osgi.wiring.package=org.dom4j.tree)
β osgi.wiring.package: (osgi.wiring.package=org.jdom2)
β osgi.wiring.package: (&(osgi.wiring.package=org.joda.time.format)(version>=1.6.0)(!(version>=2.0.0)))
β osgi.wiring.package: (osgi.wiring.package=org.kxml2.io)
β osgi.wiring.package: (&(osgi.wiring.package=org.codehaus.jettison.mapped)(version>=1.2.0)(!(version>=2.0.0)))
β osgi.wiring.package: (osgi.wiring.package=nu.xom)
β osgi.wiring.package: (osgi.wiring.package=com.bea.xml.stream)
β osgi.wiring.package: (&(osgi.wiring.package=org.joda.time)(version>=1.6.0)(!(version>=2.0.0)))
β osgi.wiring.package: (&(osgi.wiring.package=javax.xml.bind)(version>=2.3.0)(!(version>=3.0.0)))
β osgi.wiring.package: (osgi.wiring.package=org.xmlpull.v1)
β osgi.wiring.package: (osgi.wiring.package=net.sf.cglib.proxy)
β osgi.wiring.package: (osgi.wiring.package=org.dom4j)
β osgi.wiring.package: (osgi.wiring.package=org.jdom.input)
β osgi.wiring.package: (osgi.wiring.package=org.dom4j.io)
β osgi.wiring.package: (osgi.wiring.package=javax.activation)
β osgi.wiring.package: (osgi.wiring.package=org.xmlpull.mxp1)
β osgi.wiring.package: (osgi.wiring.package=org.jdom2.input)
β osgi.wiring.package: (osgi.wiring.package=com.ctc.wstx.stax)
β osgi.wiring.package: (osgi.wiring.package=com.ibm.xml.xlxp.api.stax)
β osgi.wiring.package: (osgi.wiring.package=org.jdom)
β osgi.wiring.package: (&(osgi.wiring.package=org.codehaus.jettison)(version>=1.2.0)(!(version>=2.0.0)))
[com.sun.xml.bind.jaxb-osgi version=2.3.3]
β osgi.wiring.package: (osgi.wiring.package=org.apache.tools.ant.taskdefs.compilers)
β osgi.wiring.package: (osgi.wiring.package=org.apache.tools.ant)
β osgi.wiring.package: (osgi.wiring.package=org.apache.tools.ant.types)
β osgi.wiring.package: (osgi.wiring.package=com.sun.org.apache.xml.internal.resolver)
β osgi.wiring.package: (osgi.wiring.package=com.sun.org.apache.xml.internal.resolver.tools)
β osgi.wiring.package: (osgi.wiring.package=org.apache.tools.ant.taskdefs)
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Summary for openHAB Add-ons :: Bundles :: Modbus Binding 3.1.0-SNAPSHOT:
[INFO]
[INFO] openHAB Add-ons :: Bundles :: Modbus Binding ....... SUCCESS [ 16.664 s]
[INFO] openHAB Add-ons :: Integration Tests :: Modbus Binding Tests FAILURE [ 5.358 s]
[INFO] BUILD FAILURE
[INFO] Total time: 24.098 s
[INFO] Finished at: 2021-01-29T08:39:14+02:00
[INFO] Static code analysis summary report is available in:
[INFO] file:/home/salski/src/openhab-master/git/openhab-addons/target/summary_report.html
[ERROR] Failed to execute goal biz.aQute.bnd:bnd-resolver-maven-plugin:5.2.0:resolve (default) on project org.openhab.binding.modbus.tests: Unable to resolve <<INITIAL>>: missing requirement osgi.identity;filter:='(osgi.identity=org.openhab.binding.modbus.tests)' [caused by: Unable to resolve org.openhab.binding.modbus.tests version=3.1.0.202101290639: missing requirement osgi.wiring.package;filter:='(&(osgi.wiring.package=org.junit.jupiter.api)(version>=5.7.0)(!(version>=6.0.0)))';osgi.wiring.package='org.junit.jupiter.api'] -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR] mvn <args> -rf :org.openhab.binding.modbus.tests
What could be the reason for this error?
