IVT heatpump AIRx K30RF wifi module
Hello
I’m trying to hel a friend of mine to connet his heatpump with K30RF wifi module, this heatpump is branded IVT but they a.k.a Bosch, we tried to reverse engineer by sniffin network but we do not have any luck.
Is there anyone knowing if it’s possible to get this IVT heatpump connetced to openHAB?
Using the Bosch_cli tool gives following output.
/Marcus
the K30RF will be connected to the EMS Bus of the hp. If that is right, it is easy to use the emsesp Project. Via mqtt you got a lot of information to openhab.
Thanks for your reply, I will try to see if theres any service connector on his heatpump because he didn’t want to connect wire inside cicuitboard.
Could one way be to connect open hab to IVT cloud I beleive cloud services is called anywhere II.
