Hi Tom,
Thanks for your response!!! And sorry for my late response. Life gets in the way sometime
Been testing a bit and for some reason it does not work.
I’m on heating mode at the moment and whenever I change a set point, within seconds it changes it back.
{“AirStreamDeviceUId”:“000021541”,“DeviceType”:“ASH”,“SysOn”:“on”,“SysMode”:“heat”,“SysFan”:“low”,“SleepTimer”:0,“UnitType”:“Hitachi”,“Supply”:“34.0”,“Setpoint”:“20.0”,“Temp”:“0.0”,“RAS”:“RAS”,“CtrlZone”:15,“Tag1”:“Home”,“Tag2”:“Narrabeen”,“Warnings”:“none”,“ACError”:" OK",“Id”:0,“EcoLock”:“false”,“EcoMax”:“30.0”,“EcoMin”:“18.0”,“NoOfConst”:1,“NoOfZones”:8,“SysType”:“320”,“AirflowLock”:“off”,“UnitLocked”:“false”,“FreeAir”:“disabled”,“FanAuto”:“3-speed”,“OemMake”:0}
2020-07-19 08:02:11.319 [ome.event.ItemCommandEvent] - Item ‘izone_5_setpoint’ received command 19
2020-07-19 08:02:11.322 [nt.ItemStatePredictedEvent] - izone_5_setpoint predicted to become 19
2020-07-19 08:02:11.337 [vent.ItemStateChangedEvent] - izone_5_setpoint changed from 20.0 to 19
2020-07-19 08:02:13.245 [vent.ItemStateChangedEvent] - izone_5_setpoint changed from 19 to 20.0
Could it be one of the settings on the system? I was thinking initially the master slave setting, but that’s not it.
All other settings are working perfectly. It is just the individual zone setpoint settings which are reverted back to the previous value. So the controller setpoint can be set without problems. Hopefully this helps.
And hopefully we can find a solution
Thanks heaps!!
Paul
