I swiched to OH 4.3.2. first jablotron PG and Temp work fine. Then the it stopped updating values. And I am getting this:
12:52:10.388 [WARN ] [ommon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.NumberFormatException: For input string: “unknown”
at jdk.internal.math.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:2054) ~[?:?]
at jdk.internal.math.FloatingDecimal.parseDouble(FloatingDecimal.java:110) ~[?:?]
at java.lang.Double.parseDouble(Double.java:651) ~[?:?]
at com.google.gson.stream.JsonReader.nextDouble(JsonReader.java:922) ~[?:?]
at com.google.gson.Gson$2.read(Gson.java:429) ~[?:?]
at com.google.gson.Gson$2.read(Gson.java:423) ~[?:?]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$1.readIntoField(ReflectiveTypeAdapterFactory.java:212) ~[?:?]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$FieldReflectionAdapter.readField(ReflectiveTypeAdapterFactory.java:433) ~[?:?]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:393) ~[?:?]
at com.google.gson.internal.bind.TypeAdapterRuntimeTypeWrapper.read(TypeAdapterRuntimeTypeWrapper.java:40) ~[?:?]
at com.google.gson.internal.bind.CollectionTypeAdapterFactory$Adapter.read(CollectionTypeAdapterFactory.java:82) ~[?:?]
at com.google.gson.internal.bind.CollectionTypeAdapterFactory$Adapter.read(CollectionTypeAdapterFactory.java:61) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:1227) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:1137) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:1047) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:982) ~[?:?]
at org.openhab.binding.jablotron.internal.handler.JablotronBridgeHandler.sendMessage(JablotronBridgeHandler.java:182) ~[?:?]
at org.openhab.binding.jablotron.internal.handler.JablotronBridgeHandler.sendUrlEncodedMessage(JablotronBridgeHandler.java:169) ~[?:?]
at org.openhab.binding.jablotron.internal.handler.JablotronBridgeHandler.sendGetStatusRequest(JablotronBridgeHandler.java:326) ~[?:?]
at org.openhab.binding.jablotron.internal.handler.JablotronAlarmHandler.sendGetStatusRequest(JablotronAlarmHandler.java:157) ~[?:?]
at org.openhab.binding.jablotron.internal.handler.JablotronAlarmHandler.updateAlarmStatus(JablotronAlarmHandler.java:164) ~[?:?]
at org.openhab.binding.jablotron.internal.handler.JablotronJa100Handler.controlPGMSection(JablotronJa100Handler.java:212) ~[?:?]
at org.openhab.binding.jablotron.internal.handler.JablotronJa100Handler.lambda$2(JablotronJa100Handler.java:71) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
