Jalousies controlled by sun elevation
I want to controll my jalousies dependent of the sun elevation
I tried it with this script:
var Number sollWinkel = new Float (Wetter_Elevation.state.toString) var Number sollState = Math::round(new Float (((sollWinkel*8)/11-5.454545454).toString)) var ItemList = Lamellen?.members.filter( x | x.state != 100 && x.name != "Lamelle_OG_Buero_Loggia") ItemList.forEach[ item | item.sendCommand(sollState) ]
But in the forEach-function are variables not allowed?!?
I don’t have a solution for this specific problem, but an alternative approach you might think about:
In the German forum I found this solution:
the astro binding provides elevation and azimuth, you could try to use those values in a rule:
I would recommend to save the var sollstate as a (proxy) item, just define the Item
Number sollstate "Beschattung [%d%%]"
and use
sollstate.postUpdate(Math::round(new Float (((sollWinkel*8)/11-5.454545454).toString)))
and
item.sendCommand(sollstate.state as DecimalType)
to replace the var.
It works with a proxy-Item - but not as Decimal-Type.
Instead I tried it with
item.sendCommand(new Integer (Lamelle_Soll.state.toString))
and it works!
