_tribal
(Maksim Beletskiy)
May 31, 2020, 7:14pm
1
What about apt based systems (not openhabian installation)?
mstormi
(Markus Storm)
May 31, 2020, 8:33pm
2
Youāll have to figure out yourself how to manage Java upgrades there.
Azul Zulu is not even apt based.
Or why not take the opportunity and move to openHABian
_tribal
(Maksim Beletskiy)
May 31, 2020, 8:47pm
3
I saw the post with some problems with zulu 11 and jsr223 and for now maybe i stay at v8 )
I though there was a special version OH for jdk v11
mstormi:
thanx, but i prefer armbian
FYI in case you donāt know you can run openhabian menu system on other Linux besides raspian.
matt1
(Skinah)
June 1, 2020, 12:11am
5
Please no one reply to this post as it is off topic, thanks.
FYI no you canāt do That when it is a 64bit ARM device. Java fails to install on many new ARM devices and I raised this in a GitHub issue almost 2 years ago hereā¦
opened 09:01AM - 13 Aug 18 UTC
closed 12:38PM - 04 Aug 19 UTC
enhancement
base system
Hi all,
Looking for some feedback and discussion before I make a pull requestā¦ ...
Recently I have been playing with getting an Odroid C2 running with openhab2 and found the zulu java will not install with the repo method and needs to use the "archive" method. The recommended repo simply reports that is does not support arm64 when used on Ubuntu minimal 18.04 LTS
Because of this Openhabian fails to install unless you select Oracle java. The output when it fails is..
$ apt -y install zulu-embedded-8
Reading package lists... Done
Building dependency tree
E: Unable to locate package zulu-embedded-8
FAILED
I have discussed this on the openhab forum (link below) and Markus has kindly assisted with some info so I have created some minor changes which are found in the below fork...
https://github.com/openhab/openhabian/compare/master...Skinah:master
There are a number of changes I would like to discuss on top of what is in the fork and they are:
1. Raw image for the odroid only has a single user "root". Would be good to auto create a new 'everyday user' which does not appear to happen with my testing as the openhabian-setup script simply asks you on first run what user you already have.
2. A check for warning the user that their root account still needs the password changed from the default 'odroid' value.
3. Manual/fresh setup (option 60) does not offer the manual 'zulu archive' method to install java. Could this be added. There will be users wanting this with Odoroid XU4, and many other arm64 devices not just C2 owners.
Discussion on forum is here.
https://community.openhab.org/t/how-to-easily-install-openhab2-on-odroid-c2-arm64/49194
The changes needed to make it work are funnily sitting in the project disabled/ commented out. I begun to make Changes for a PR and they are still sitting here.
https://github.com/Skinah/openhabian
ndye
(Ethan Dye)
June 1, 2020, 12:57am
7
64-bit ARM support has been added for devices that can be used with it (which does not currently include the RPi3 or RPi4). Please try to use the new install routine and see if it still fails, if it does let me know and I can help to fix it.
This is the entire reason for this test to find and fix bugs. In this case it would likely be a bug as 64-bit Java is now supposed to install correctly. Additionally, the PR changes you mentioned are no longer applicable as the code has changed greatly since they were made.
matt1
(Skinah)
June 1, 2020, 10:20am
8
ndye:
I know of two users that have been playing with an Odroid C4 last week that had issues using openhabian on top of Debian/Ubuntu images. Most non PI users have been using DietPI and Armbian as they offer to install openhab for youā¦ I checked the scripts that Openhabian uses and yes a lot of work has been done, a BIG THANKYOU to all that have contributedā¦
I just tried it 5 minutes ago, and yes it still fails to install Java for the main ubuntu 18-04-3 LTS minimal image for an Odroid C2. I was using STABLE branch for the below.
First tried option 3 and that failed to create a working Openhab with complaints that there was no JAVA installed (I kept the console output saved to a txt file).
Then I tried option 63 to manual install java, this is the output and it appears curl is not installed.
root@odroid:~# openhabian-config
2020-06-01_09:09:16_UTC [openHABian] Checking for root privileges... OK
2020-06-01_09:09:16_UTC [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2020-06-01_09:09:16_UTC [openHABian] openHABian configuration tool version: [stable]v1.5-588(2c8471e)
2020-06-01_09:09:16_UTC [openHABian] Checking for changes in origin branch stable ... OK
2020-06-01_09:09:18_UTC [openHABian] Switching to branch stable ... OK
2020-06-01_09:09:48_UTC [openHABian] Updating Linux package information ...
2020-06-01_09:10:25_UTC [openHABian] Updating Linux package information ...
2020-06-01_09:11:24_UTC [openHABian] Updating Linux package information ...
2020-06-01_09:11:25_UTC [openHABian] Installing Java Zulu 32-Bit OpenJDK... /opt/openhabian/functions/java-jre.bash: line 149: curl: command not found
gzip: stdin: unexpected end of file
tar: Child returned status 1
tar: Error is not recoverable: exiting now
FAILED
2020-06-01_09:11:43_UTC [openHABian] Checking for default openHABian username:password combination... SKIPPED (method not implemented)
2020-06-01_09:11:43_UTC [openHABian] We hope you got what you came for! See you again soon ;)
apt install curl
worked to install curl with default repos untouched and then tried again, this time I got a working Openhab. Frontail installed smoothly too. Lastly I changed to MASTER and upgraded the java to 32bit version 11 and it worked. Will move some bindings and files across to do some testing over the next few days.
J-N-K
(Jan N. Klug)
June 1, 2020, 11:35am
9
OH3 will fully support Java 11. I run OH2.5 on Java11, BUT: it wonāt work out-of-the-box if you use bindings that have serial communication or use jython. JavaScript scripting works though.
Edit: my comment regarding serial communication is valid only for windows.
mstormi
(Markus Storm)
June 1, 2020, 11:53am
10
J-N-K:
Please check back with @5iver , he said to use OpenJDK11 with jython 2.7.2 with no problems.
I didnāt closely follow this nrjserial stuff, does 2.5 still use some old version to conflict with Java 11 because of core freeze ? What should I mention in the announcement post to NOT open as threads because it is a known issue ? Any serial related exception ?
[ if that means you cannot run anything-to-use-serial because of that Iād put a big question mark behind the core freeze as it would IMHO mean only very few people can go Java 11 today but everyone has to use it right from the start with OH3 ]
ranielsen
(Rob Nielsen)
June 1, 2020, 12:12pm
11
mstormi:
@wborn reversioned 5.2.1 as nrjavaserial-3.15.0.OH2.jar . Iāve been using it with Java 11 with no issues.
J-N-K
(Jan N. Klug)
June 1, 2020, 12:15pm
12
Exactly. But this requires manual upgrade for OH2.5, therefore my warning āwill not work out-of-the-boxā
5iver
(Scott Rushworth)
June 1, 2020, 4:21pm
13
mstormi:
There was a change around S1760, where there is an error when using the manual Jython installation, but the beta bundle works fine.
opened 09:49AM - 01 Dec 19 UTC
closed 04:37PM - 23 May 20 UTC
automation
I've been using [Jython 2.7.2b2](https://mvnrepository.com/artifact/org.python/jā¦ ython-standalone/2.7.2b2) without issues since it came out earlier this month, but only in a test environment that was on S1749. After updating OH to S1760, I'm getting the following errors. In production, I use a build of Jython 2.7.2a1+ from earlier in the year and it works without issues on S1764, so it looks to be something that changed in OH.
2019-12-01 04:43:47.973 [ERROR] [org.openhab.core.automation.module.script] - bundle org.openhab.core.automation.module.script:2.5.0.201912010653 (229)[org.openhab.core.automation.module.script.internal.ScriptEngineManagerImpl(273)] : The addScriptEngineFactory method has thrown an exception
java.lang.ExceptionInInitializerError: null
at org.python.core.PyJavaType.isAccessibleClass(PyJavaType.java:656) ~[?:?]
at org.python.core.PyJavaType.init(PyJavaType.java:450) ~[?:?]
at org.python.core.PyType$Registry.createType(PyType.java:430) ~[?:?]
at org.python.core.PyType$Registry.addFromClass(PyType.java:379) ~[?:?]
at org.python.core.PyType$Registry.resolveType(PyType.java:296) ~[?:?]
at org.python.core.PyType$Registry$1.computeValue(PyType.java:210) ~[?:?]
at org.python.core.PyType$Registry$1.computeValue(PyType.java:204) ~[?:?]
at java.lang.ClassValue.getFromHashMap(ClassValue.java:227) ~[?:1.8.0_222]
at java.lang.ClassValue.getFromBackup(ClassValue.java:209) ~[?:1.8.0_222]
at java.lang.ClassValue.get(ClassValue.java:115) ~[?:1.8.0_222]
at org.python.core.PyType.fromClass(PyType.java:2056) ~[?:?]
at org.python.core.PyJavaType$Constant.<clinit>(PyJavaType.java:96) ~[?:?]
at org.python.core.PyType$Registry.createType(PyType.java:417) ~[?:?]
at org.python.core.PyJavaType.<clinit>(PyJavaType.java:101) ~[?:?]
at org.python.core.PyType$Registry.createType(PyType.java:408) ~[?:?]
at org.python.core.PyType$Registry.resolveType(PyType.java:313) ~[?:?]
at org.python.core.PyObject.<init>(PyObject.java:85) ~[?:?]
at org.python.core.PySingleton.<init>(PySingleton.java:9) ~[?:?]
at org.python.core.PyNotImplemented.<init>(PyNotImplemented.java:10) ~[?:?]
at org.python.core.Py.<clinit>(Py.java:66) ~[?:?]
at org.python.core.PySystemState.<clinit>(PySystemState.java:72) ~[?:?]
at org.python.util.PythonInterpreter.threadLocalStateInterpreter(PythonInterpreter.java:80) ~[?:?]
at org.python.jsr223.PyScriptEngine.<init>(PyScriptEngine.java:27) ~[?:?]
at org.python.jsr223.PyScriptEngineFactory.getScriptEngine(PyScriptEngineFactory.java:85) ~[?:?]
at javax.script.ScriptEngineManager.getEngineByExtension(ScriptEngineManager.java:288) ~[?:1.8.0_222]
at org.openhab.core.automation.module.script.scriptenginefactory.jython.JythonScriptEngineFactory.createScriptEngine(JythonScriptEngineFactory.java:70) ~[?:?]
at org.openhab.core.automation.module.script.internal.ScriptEngineManagerImpl.addScriptEngineFactory(ScriptEngineManagerImpl.java:73) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_222]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_222]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_222]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_222]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.invoke(BindMethod.java:42) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1813) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.bindDependency(DependencyManager.java:1637) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.bind(DependencyManager.java:1624) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:307) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:982) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:955) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:900) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) ~[org.eclipse.osgi-3.12.100.jar:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:1.8.0_222]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) ~[org.eclipse.osgi-3.12.100.jar:?]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) ~[osgi.core-6.0.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1045) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:999) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:666) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:432) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:338) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:382) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:264) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[osgi.core-6.0.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:402) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.karaf.features.internal.service.BundleInstallSupportImpl.startBundle(BundleInstallSupportImpl.java:165) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1153) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:1036) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1062) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:998) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
Caused by: java.lang.NullPointerException
at org.python.core.PrePy.getEffectiveLoggingLevel(PrePy.java:113) ~[?:?]
at org.python.core.PrePy.getLoggingLevel(PrePy.java:121) ~[?:?]
at org.python.core.Options.<clinit>(Options.java:83) ~[?:?]
... 143 more
2019-12-01 04:43:48.466 [ERROR] [org.openhab.core.automation.module.script] - bundle org.openhab.core.automation.module.script:2.5.0.201912010653 (229)[org.openhab.core.automation.module.script.internal.provider.ScriptModuleTypeProvider(277)] : The setScriptEngineFactory method has thrown an exception
java.lang.NoClassDefFoundError: Could not initialize class org.python.core.PySystemState
at org.openhab.core.automation.module.script.internal.provider.ScriptModuleTypeProvider.setScriptEngineFactory(ScriptModuleTypeProvider.java:142) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry$ProviderTracker.addingService(AbstractRegistry.java:130) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry$ProviderTracker.addingService(AbstractRegistry.java:1) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:318) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261) ~[osgi.core-6.0.0.jar:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.activate(AbstractRegistry.java:102) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:340) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:86) ~[?:?]
at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:664) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2308) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.prebind(DependencyManager.java:1154) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1568) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1029) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:935) ~[?:?]
More detail at the end of this commentā¦
opened 09:53AM - 07 Jan 20 UTC
closed 08:22PM - 09 Oct 20 UTC
My proposal is to remove all things automation from OHC and move them to a new oā¦ penHAB repository. I see this new repository being the potential home for the following (maybe more):
* Rule engines
* Scripted automation (if separated out of the NGRE)
* ScriptEngineFactories
* DSL (if kept in OH 3.0)
* Migration tool for .rules files (if the DSL is not kept in OH 3.0)
* Automation bundles
* ModuleTypes
* Rule templates (possibly separated in future)
* ExtensionService for openHAB automation marketplace (or will there be one with a larger scope?)
The NGRE introduces several new pieces to OH automation that should be maintained in a central location. For example, there are Jython (#1253) and JavaScript ScriptEngineFactory PRs pending review, but we first need to decide on where they should be maintained. Right behind these will be Groovy, jRuby, and Kotlin ScriptEngineFactories. There will also soon be a deluge of rule templates.
I do not think any of these fit well in OHC. Separating automation from OHC will also allow for dependencies on addons to be placed on automation bundles, rule templates, etc., which would not be allowed if these bundles were kept in OHC.
mstormi
(Markus Storm)
June 1, 2020, 7:21pm
14
Well if you donāt run the unattended install you of course need to install prerequisites first, one by one. Thatās menu 10 for the most part - curl is among ābasic canāt be wrongā packages.
But to be safe you should run openhabian-config unattended
, did you ?
Honestly I donāt know if that works as Iāve never tried on anything but Raspbian, but in theory that should do.
matt1
(Skinah)
June 2, 2020, 12:26am
15
mstormi:
, did you ?
I followed the install guide here so if your telling me it needs to be started as unattended the guide needs updating.
I also have issues with samba not working, have not had time to narrow the cause yet but I suspect it may be because there is no openhabian user account created.
smitopher
(Christopher Smith)
June 2, 2020, 6:58pm
16
Well, I just upgraded to Ubuntu Server 20.04 and I thought Iād try OpenJDK 11
I removed Oracle JDK 8 and installed OpenJDK 11 using apt
I donāt use any of the plug-ins or serial communications.
Openhab started right up and runs like nothing happened.
smitopher
(Christopher Smith)
June 2, 2020, 6:59pm
17
although this was in the log
smitopher@myth-server:~$ sudo systemctl status openhab2.service
[sudo] password for smitopher:
ā openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2020-06-02 13:50:37 CDT; 1min 5s ago
Docs: https://www.openhab.org/docs/
Main PID: 1122 (java)
Tasks: 228 (limit: 9298)
Memory: 782.0M
CGroup: /system.slice/openhab2.service
āā1122 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.logdir=/var/log/openhab2 -D>
Jun 02 13:50:37 myth-server systemd[1]: Started openHAB 2 - empowering the smart home.
Jun 02 13:50:41 myth-server karaf[1122]: org.ops4j.pax.url.wrap [org.ops4j.pax.url.commons.handler.HandlerActivator] DEBUG : Handler for protocols [wrap] started
Jun 02 13:50:59 myth-server karaf[1122]: Warning: Nashorn engine is planned to be removed from a future JDK release
J-N-K
(Jan N. Klug)
June 2, 2020, 7:01pm
18
Yes, we need to replace Nashorn at some time. But in Java 11 itās only a deprecation warning and everything works as expected.
wborn
(Wouter Born)
June 3, 2020, 12:09pm
19
These are suppressed in 2.5.6-SNAPSHOT after backporting the āfixā from OH3:
committed 10:37AM - 23 May 20 UTC
Suppresses the Nashorn deprecation warnings that show on startup on newer Java vā¦ ersions:
See also: https://bugs.openjdk.java.net/browse/JDK-8210140
Signed-off-by: Wouter Born <github@maindrain.net>
On windows 10 I got same error message and it does not matter witch Java version OpenJDK or Zulu I use:
Launching the openHAB runtime...
Listening for transport dt_socket at address: 5005
__ _____ ____
____ ____ ___ ____ / / / / | / __ )
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ |
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/
/_/ 2.5.6-SNAPSHOT
Build #138
Hit '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
Hit '<ctrl-d>' or type 'system:shutdown' or 'logout' to shutdown openHAB.
openhab> Exception in thread "OkHttp Dispatcher" java.lang.IllegalArgumentException: unsupported auth scheme: [Basic realm="gSOAP Web Service"]
at com.burgstaller.okhttp.digest.DigestAuthenticator.findDigestHeader(DigestAuthenticator.java:199)
at com.burgstaller.okhttp.digest.DigestAuthenticator.authenticate(DigestAuthenticator.java:164)
at com.burgstaller.okhttp.CachingAuthenticatorDecorator.authenticate(CachingAuthenticatorDecorator.java:35)
at okhttp3.internal.http.RetryAndFollowUpInterceptor.followUpRequest(RetryAndFollowUpInterceptor.kt:213)
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.kt:102)
Exception in thread "OkHttp Dispatcher" Exception in thread "OkHttp Dispatcher" at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:112)
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:87)
at com.burgstaller.okhttp.AuthenticationCacheInterceptor.intercept(AuthenticationCacheInterceptor.java:49)
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.kt:184)
at okhttp3.RealCall$AsyncCall.run(RealCall.kt:136)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.base/java.lang.Thread.run(Unknown Source)
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.jboss.netty.util.internal.ByteBufferUtil (file:/C:/openhab2/userdata/cache/org.eclipse.osgi/275/0/.cp/lib/netty-3.9.0.Final.jar) to method java.nio.DirectByteBuffer.cleaner()
WARNING: Please consider reporting this to the maintainers of org.jboss.netty.util.internal.ByteBufferUtil
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
J-N-K
(Jan N. Klug)
June 5, 2020, 10:43pm
21
Which binding is not working? Unfortunately there is not much in this stack trace. If you canāt say which binding, please provide a list of all installed bindings and additionally the output of bundle:list -s | grep 275
. Thanks.
