- Platform information:
- Hardware: Core I3, 16 GB , 512 HDD
- OS: Win10 Pro
- Java Runtime Environment: jdk1.8.0_181
- openHAB version: 2.5.8 running as a windows service
- Issue of the topic: OutOfMemoryException, Java using 850MB only
Hi all,
I had a couple od issues with performance and then went into the log and found : “OutOuMemoryException”.
Then went into taskmanager: 860MB only - more than half of mem of PC was free
Then I tried to set in global environment vars on the machine:
EXTRA_JAVA_OPTS “-Xms400m -Xmx4g”
Restareted service an computer a couple of times - same behaviour
Then startet openhab by “start.bat” and in karaf.bat I had changed:
rem Check/Set up some easily accessible MIN/MAX params for JVM mem usage
if “%JAVA_MIN_MEM%” == “” (
set JAVA_MIN_MEM=128M
if “%JAVA_MAX_MEM%” == “” (
set JAVA_MAX_MEM=4G
rem set JAVA_MAX_MEM=512M
This has solved my memory issues and OH is now using more that 1GB Mem - seems that this is what it wanted and did’nt get before.
Now my question:
How can I do the same with the windows service instead of using the manual start via kara.bat?
Thank you for your help in advance.
Cheers
E.
