I am trying to create a rule which is run when 1 of 2 relays is changed. To clearify more:
1 relay is a transformer which is converting power for solenoid 1 and 2. PumpRelay01 and 02 are the solenoid relays. The pumps can therefore only be run with pumprelay01 + transformer, pumprelay02 + transformer, pumprelay01 + pumprelay02 + transformer, you get the idea.
I have some experience in Java so I was tinking of using a Java switch in my code, however I do not seem to get it to work and searching on either case or switch does not give me any answer if it is working.
Would someone be so nice to help me out (wheter this is going to work and if the switch is supported)
import org.joda.time.*
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
rule "Switch transformer ON/OFF"
Item Pump01 changed or
Item Pump02 changed or
Item Relay02 changed
switch {
case Pump01.state==ON AND Pump02.state==ON AND Relay02.state==ON:
// Do nothing, switches correct
break;
case Pump01.state==ON AND Pump02.state==ON AND Relay02.state==OFF:
// Turn Relay02 ON
sendCommand(Relay02, ON);
break;
case Pump01.state==OFF AND Pump02.state==ON AND Relay02.state==ON:
break;
case Pump01.state==OFF AND Pump02.state==ON AND Relay02.state==OFF:
// Turn Relay02 ON
break;
case Pump01.state==ON AND Pump02.state==OFF AND Relay02.state==ON:
break;
case Pump01.state==ON AND Pump02.state==OFF AND Relay02.state==OFF:
// Turn Relay02 ON
break;
case Pump01.state==OFF AND Pump02.state==OFF AND Relay02.state==OFF:
break;
case Pump01.state==OFF AND Pump02.state==OFF AND Relay02.state==ON:
// Turn Relay02 OFF
sendCommand(Relay02, OFF);
break;
default: break;
You are right, switch in java is only able to handle 1 variable and not the 3 like I wanted.
What is possible to do I think is to merge the 3 variables to 3bit length value: 010 (pump1 off, pump2 on, transformer off).
Then I can just match all cases like:
case ‘010’: “do something or not”
An important thing to realize is that even though Java classes are available in the rules, the Rules and Scripts are written in the Xtend language, not Java. Switch statements in Xtend work significantly differently than they do in Java.
Also, I think the symbol for AND should actually be &&.
That being said, something like this might work:
switch Pump01 {
case Pump01.state==ON && Pump02.state==ON && Relay02.state==OFF: sendCommand(Relay02, ON)
case Pump01.state==OFF && Pump02.state==ON && Relay02.state==OFF: sendCommand(Relay02, ON)
case Pump01.state==ON && Pump02.state==OFF && Relay02.state==OFF: sendCommand(Relay02, ON)
case Pump01.state==OFF && Pump02.state==OFF && RElay02.state==OFF: sendCommand(Relay02, OFF)
There is no need to have cases that do nothing in the statement. I’m not sure if Xtend will even let you do that actually. One big thing to note about Xtend switch statements is that they do not fall through so there is no need for the breaks.
That being said, I think you can collapse this into a single if/else statement:
if(Relay02.state == OFF && (Pump01.state==ON || Pump02.state==ON)) sendCommand(Relay02, ON)
else if(Relay02.state == ON && Pump01.state == OFF && Pump02.state==ON) sendCommand(Relay02, OFF)
