I am using openhab 1.8.2.
Today i had to restart openhab (running on a raspberry pi 3).
I can access openhab with a browser on my pc.
When i try to open the openHAB App on my android phone it says:
“javax.servlet.ServletException: Throwable”.
When i look in the openhab.log i find the following stacktrace:
2017-03-15 17:49:30.038 [ERROR] [.a.h.ReflectorServletProcessor] - onRequest()
at org.atmosphere.util.AtmosphereFilterChain.doFilter(AtmosphereFilterChain.java:151) ~[atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.util.AtmosphereFilterChain.invokeFilterChain(AtmosphereFilterChain.java:96) ~[atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.handler.ReflectorServletProcessor$FilterChainServletWrapper.service(ReflectorServletProcessor.java:317) ~[atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.handler.ReflectorServletProcessor.onRequest(ReflectorServletProcessor.java:160) ~[atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AsynchronousProcessor.action(AsynchronousProcessor.java:206) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AsynchronousProcessor.suspended(AsynchronousProcessor.java:105) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.container.Jetty7CometSupport.service(Jetty7CometSupport.java:57) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.container.JettyAsyncSupportWithWebSocket.service(JettyAsyncSupportWithWebSocket.java:67) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereFramework.doCometSupport(AtmosphereFramework.java:2076) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereServlet.doPost(AtmosphereServlet.java:211) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereServlet.doGet(AtmosphereServlet.java:197) [atmosphere-runtime-2.2.5.jar:2.2.5]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:735) [javax.servlet_3.0.0.v201112011016.jar:na]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848) [javax.servlet_3.0.0.v201112011016.jar:na]
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:68) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598) [org.eclipse.jetty.servlet_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486) [org.eclipse.jetty.servlet_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413) [org.eclipse.jetty.servlet_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:250) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:149) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.Server.handle(Server.java:350) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:890) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:944) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:630) [org.eclipse.jetty.http_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230) [org.eclipse.jetty.http_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:606) [org.eclipse.jetty.io_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:46) [org.eclipse.jetty.io_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603) [org.eclipse.jetty.util_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538) [org.eclipse.jetty.util_8.1.3.v20120522.jar:8.1.3.v20120522]
at java.lang.Thread.run(Thread.java:745) [na:1.8.0_65]
Caused by: java.lang.ClassFormatError: com/sun/xml/internal/bind/v2/runtime/unmarshaller/IntData
at com.sun.xml.internal.bind.v2.runtime.XMLSerializer.(XMLSerializer.java:182) ~[na:1.8.0_65]
at com.sun.xml.internal.bind.v2.runtime.MarshallerImpl.(MarshallerImpl.java:137) ~[na:1.8.0_65]
at com.sun.xml.internal.bind.v2.runtime.JAXBContextImpl.createMarshaller(JAXBContextImpl.java:738) ~[na:1.8.0_65]
at com.sun.xml.internal.bind.v2.runtime.JAXBContextImpl.createMarshaller(JAXBContextImpl.java:124) ~[na:1.8.0_65]
at com.sun.jersey.core.provider.jaxb.AbstractJAXBProvider.getMarshaller(AbstractJAXBProvider.java:166) ~[jersey-core-1.18.1.jar:1.18.1]
at com.sun.jersey.core.provider.jaxb.AbstractJAXBProvider.getMarshaller(AbstractJAXBProvider.java:145) ~[jersey-core-1.18.1.jar:1.18.1]
at com.sun.jersey.core.provider.jaxb.AbstractRootElementProvider.writeTo(AbstractRootElementProvider.java:151) ~[jersey-core-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.ContainerResponse.write(ContainerResponse.java:302) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1510) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1419) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1409) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.servlet.WebComponent.service(WebComponent.java:409) ~[jersey-servlet-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:540) ~[jersey-servlet-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:715) ~[jersey-servlet-1.18.1.jar:1.18.1]
at org.atmosphere.util.AtmosphereFilterChain.doFilter(AtmosphereFilterChain.java:135) ~[atmosphere-runtime-2.2.5.jar:2.2.5]
… 39 common frames omitted
2017-03-15 17:49:30.089 [WARN ] [e.jetty.servlet.ServletHandler] - /rest/sitemaps
java.lang.RuntimeException: javax.servlet.ServletException: Throwable
at org.atmosphere.handler.ReflectorServletProcessor.onRequest(ReflectorServletProcessor.java:163) ~[na:na]
at org.atmosphere.cpr.AsynchronousProcessor.action(AsynchronousProcessor.java:206) ~[na:na]
at org.atmosphere.cpr.AsynchronousProcessor.suspended(AsynchronousProcessor.java:105) ~[na:na]
at org.atmosphere.container.Jetty7CometSupport.service(Jetty7CometSupport.java:57) ~[na:na]
at org.atmosphere.container.JettyAsyncSupportWithWebSocket.service(JettyAsyncSupportWithWebSocket.java:67) ~[na:na]
at org.atmosphere.cpr.AtmosphereFramework.doCometSupport(AtmosphereFramework.java:2076) ~[na:na]
at org.atmosphere.cpr.AtmosphereServlet.doPost(AtmosphereServlet.java:211) ~[na:na]
at org.atmosphere.cpr.AtmosphereServlet.doGet(AtmosphereServlet.java:197) ~[na:na]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:735) ~[javax.servlet_3.0.0.v201112011016.jar:na]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848) ~[javax.servlet_3.0.0.v201112011016.jar:na]
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61) ~[na:na]
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128) ~[na:na]
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:68) ~[na:na]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598) ~[org.eclipse.jetty.servlet_8.1.3.v20120522.jar:8.1.3.v20120522]
Caused by: javax.servlet.ServletException: Throwable
at org.atmosphere.util.AtmosphereFilterChain.doFilter(AtmosphereFilterChain.java:151) ~[na:na]
at org.atmosphere.util.AtmosphereFilterChain.invokeFilterChain(AtmosphereFilterChain.java:96) ~[na:na]
at org.atmosphere.handler.ReflectorServletProcessor$FilterChainServletWrapper.service(ReflectorServletProcessor.java:317) ~[na:na]
at org.atmosphere.handler.ReflectorServletProcessor.onRequest(ReflectorServletProcessor.java:160) ~[na:na]
… 36 common frames omitted
at com.sun.jersey.core.provider.jaxb.AbstractJAXBProvider.getMarshaller(AbstractJAXBProvider.java:166) ~[na:na]
at com.sun.jersey.core.provider.jaxb.AbstractJAXBProvider.getMarshaller(AbstractJAXBProvider.java:145) ~[na:na]
at com.sun.jersey.core.provider.jaxb.AbstractRootElementProvider.writeTo(AbstractRootElementProvider.java:151) ~[na:na]
at com.sun.jersey.spi.container.ContainerResponse.write(ContainerResponse.java:302) ~[na:na]
at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1510) ~[na:na]
at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1419) ~[na:na]
at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1409) ~[na:na]
at com.sun.jersey.spi.container.servlet.WebComponent.service(WebComponent.java:409) ~[na:na]
at com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:540) ~[na:na]
at com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:715) ~[na:na]
at org.atmosphere.util.AtmosphereFilterChain.doFilter(AtmosphereFilterChain.java:135) ~[na:na]
