Hello all,
I get this error
2022-12-31 15:58:17.376 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class org.mariadb.jdbc.MariaDbBlob cannot be cast to class java.lang.String (org.mariadb.jdbc.MariaDbBlob is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @73bc1c2c; java.lang.String is in module java.base of loader 'bootstrap')
java.lang.ClassCastException: class org.mariadb.jdbc.MariaDbBlob cannot be cast to class java.lang.String (org.mariadb.jdbc.MariaDbBlob is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @73bc1c2c; java.lang.String is in module java.base of loader 'bootstrap')
at org.openhab.persistence.jdbc.internal.db.JdbcBaseDAO.objectAsString(JdbcBaseDAO.java:734) ~[?:?]
at org.openhab.persistence.jdbc.internal.db.JdbcBaseDAO.objectAsState(JdbcBaseDAO.java:689) ~[?:?]
at org.openhab.persistence.jdbc.internal.db.JdbcBaseDAO.lambda$0(JdbcBaseDAO.java:479) ~[?:?]
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195) ~[?:?]
at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1655) ~[?:?]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484) ~[?:?]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474) ~[?:?]
at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:913) ~[?:?]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:?]
at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:578) ~[?:?]
at org.openhab.persistence.jdbc.internal.db.JdbcBaseDAO.doGetHistItemFilterQuery(JdbcBaseDAO.java:480) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.getHistItemFilterQuery(JdbcMapper.java:236) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.query(JdbcPersistenceService.java:226) ~[?:?]
at jdk.internal.reflect.GeneratedMethodAccessor137.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
how do I determine which element is meant and how to solve this issue? Thanks for the help appreciated
