Hi there,
i made some changes at my local Server and switche to ESXi with VMs.
Before this i made a backup of my MySQL database und afterwards recovered this backup.
It seems like the backup made a mistake at the datatypes.
31 of my tables now have the datatype DOUBLE
Is there any information what datatypes are correct?
The problem is that openHAB can´t store value into tables with the datatype DOUBLE
2019-05-24 11:36:20.246 [ERROR] [org.knowm.yank.Yank ] - Error in SQL query!!!
java.sql.SQLException: Data truncation: Incorrect datetime value: '24.4' for column 'Value' at row 1 Query: INSERT INTO Item4 (TIME, VALUE) VALUES( NOW(3), ? ) ON DUPLICATE KEY UPDATE VALUE= ? Parameters: [24.4, 24.4]
at org.apache.commons.dbutils.AbstractQueryRunner.rethrow(AbstractQueryRunner.java:392) ~[252:org.openhab.persistence.jdbc:1.13.0]
at org.apache.commons.dbutils.QueryRunner.update(QueryRunner.java:491) ~[252:org.openhab.persistence.jdbc:1.13.0]
at org.apache.commons.dbutils.QueryRunner.update(QueryRunner.java:457) ~[252:org.openhab.persistence.jdbc:1.13.0]
at org.knowm.yank.Yank.execute(Yank.java:194) [252:org.openhab.persistence.jdbc:1.13.0]
at org.knowm.yank.Yank.execute(Yank.java:177) [252:org.openhab.persistence.jdbc:1.13.0]
at org.openhab.persistence.jdbc.db.JdbcBaseDAO.doStoreItemValue(JdbcBaseDAO.java:332) [252:org.openhab.persistence.jdbc:1.13.0]
at org.openhab.persistence.jdbc.internal.JdbcMapper.storeItemValue(JdbcMapper.java:141) [252:org.openhab.persistence.jdbc:1.13.0]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.store(JdbcPersistenceService.java:133) [252:org.openhab.persistence.jdbc:1.13.0]
at org.openhab.core.persistence.internal.PersistenceServiceDelegate.store(PersistenceServiceDelegate.java:55) [197:org.openhab.core.compat1x:2.4.0]
at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.handleStateEvent(PersistenceManagerImpl.java:148) [106:org.eclipse.smarthome.core.persistence:0.10.0.oh240]
at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.stateUpdated(PersistenceManagerImpl.java:469) [106:org.eclipse.smarthome.core.persistence:0.10.0.oh240]
at org.eclipse.smarthome.core.items.GenericItem$1.run(GenericItem.java:249) [102:org.eclipse.smarthome.core:0.10.0.oh240]
It seems like openHAB messed up the mappings between items and the correct tables…
Item4 should be a datetime string 2018-12-12 19:57:16
but openHAB tries to store a temperature value into this table.
How to fix this messed up mappings without loosing the stored data?
- Platform information:
- Hardware: Raspberry Pi 3B
- OS: raspbian 9
- Java Runtime Environment:
- openjdk version “1.8.0_152”
OpenJDK Runtime Environment (Zulu Embedded 8.25.0.76-linux-aarch32hf)
OpenJDK Client VM (Zulu Embedded 8.25.0.76-linux-aarch32hf)
- openHAB version: 2.3.0-1 (Release Build)
