I am trying to save item states values into DB.
I have been used openhab compatibility layer and org.openhab.persistence.jdbc bindings and sqlite-jdbc-3.21.0 driver , it’s being in ACTIVE.
Here openhab compatibility and org.openhab.persistence.jdbc and sqlite-jdbc-3.21.0 jar files added to deplay folder in ESH repo.
According to openhab official documentation to configured below jdbc related files.
openhab.cfg file
############################ SQL Persistence Service ##################################
# the database url like 'jdbc:mysql://<host>:<port>/<database>' (without quotes)
mysql:url=jdbc:sqlite:./testSqlite.db
# the database user
mysql:user=TEST
# the database password
mysql:password=TEST
# the reconnection counter
#mysql:reconnectCnt=
# the connection timeout (in seconds)
#mysql:waitTimeout=
# Use MySQL Server time to store item values (=false) or use openHAB Server time (=true).
# For new installations, its recommend to set "mysql:localtime=true".
# (optional, defaults to false)
#mysql:localtime=true
jdbc.cfg file
############################ JDBC Persistence Service ##################################
# I N S T A L L J D B C P E R S I S T E N C E S E R V I C E
# https://github.com/openhab/openhab/wiki/JDBC-Persistence
# Tested databases/url-prefix: jdbc:derby, jdbc:h2, jdbc:hsqldb, jdbc:mariadb, jdbc:mysql, jdbc:postgresql, jdbc:sqlite
# derby, h2, hsqldb, sqlite can be embedded,
# If no database is available it will be created, for example the url 'jdbc:h2:./testH2' creates a new DB in OpenHab Folder.
# Create new database, for example on a MySQL-Server use:
# CREATE DATABASE 'yourDB' CHARACTER SET utf8 COLLATE utf8_general_ci;
# D A T A B A S E C O N F I G
# Some URL-Examples, 'service' identifies and activates internally the correct jdbc driver.
# required database url like 'jdbc:<service>:<host>[:<port>;<attributes>]'
# url=jdbc:derby:./testDerby;create=true
# url=jdbc:h2:./testH2
# url=jdbc:hsqldb:./testHsqlDb
# url=jdbc:mariadb://192.168.0.1:3306/testMariadb
# url=jdbc:mysql://192.168.0.1:3306/testMysql
# url=jdbc:postgresql://192.168.0.1:5432/testPostgresql
# url=jdbc:sqlite:./testSqlite.db
# url=
url=jdbc:sqlite:./database/openhab.db
# required database user
user=TEST
# required database password
password=TEST
# E R R O R H A N D L I N G
# optional when Service is deactivated (optional, default: 0 -> ignore)
errReconnectThreshold=0
# I T E M O P E R A T I O N S
# optional tweaking SQL datatypes
# see: https://mybatis.github.io/mybatis-3/apidocs/reference/org/apache/ibatis/type/JdbcType.html
# see: http://www.h2database.com/html/datatypes.html
# see: http://www.postgresql.org/docs/9.3/static/datatype.html
# defaults:
sqltype.CALL = VARCHAR(200)
sqltype.COLOR = VARCHAR(70)
sqltype.CONTACT = VARCHAR(6)
sqltype.DATETIME = DATETIME
sqltype.DIMMER = TINYINT
sqltype.LOCATION = VARCHAR(30)
sqltype.NUMBER = DOUBLE
sqltype.ROLLERSHUTTER = TINYINT
sqltype.STRING = VARCHAR(65500)
sqltype.SWITCH = VARCHAR(6)
# For Itemtype "Number" default decimal digit count (optional, default: 3)
numberDecimalcount=3
# T A B L E O P E R A T I O N S
# Tablename Prefix String (optional, default: "item")
# for Migration from MYSQL-Bundle set to 'Item'.
tableNamePrefix=Item
# Tablename Prefix generation, using Item real names or "item" (optional, default: false -> "item")
# If true, 'tableNamePrefix' is ignored.
tableUseRealItemNames=false
# Tablename Suffix length (optional, default: 4 -> 0001-9999)
# for Migration from MYSQL-Bundle set to 0.
tableIdDigitCount=4
# Rename existing Tables using tableUseRealItemNames and tableIdDigitCount (optional, default: false)
# USE WITH CARE! Deactivate after Renaming is done!
rebuildTableNames=false
# D A T A B A S E C O N N E C T I O N S
# Some embeded Databases can handle only one Connection (optional, default: configured per database in packet org.openhab.persistence.jdbc.db.* )
# see: https://github.com/brettwooldridge/HikariCP/issues/256
# jdbc.maximumPoolSize = 1
# jdbc.minimumIdle = 1
# T I M E K E E P I N G
# (optional, default: false)
enableLogTime=false
jdbc.persist file
Strategies {
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
Items {
// persist all items once a day and on every change and restore them from the db at startup
* : strategy = everyChange, everyDay, restoreOnStartup
When I was trying to store item states values into DB…it’s showing some below
17:22:20.124 INFO [safeCall-1] Item 'light2' received command ON
17:22:20.128 INFO [safeCall-2] light2 changed from NULL to ON
17:22:20.128 INFO [safeCall-3] light2 updated to ON
17:22:20.124 DEBUG [items-1] JDBC::pingDB
17:22:20.148 DEBUG [items-1] JDBC::openConnection isDriverAvailable: false
17:22:20.160 WARN [items-1] JDBC::openConnection: no driver available!
17:22:20.160 DEBUG [items-1] JDBC::pingDB
17:22:20.168 DEBUG [items-1] JDBC::openConnection isDriverAvailable: false
17:22:20.174 WARN [items-1] JDBC::openConnection: no driver available!
17:22:20.177 DEBUG [items-1] JDBC::checkDBAcessability, second try connection: false
17:22:20.177 WARN [items-1] JDBC::store: No connection to database. Cannot persist item 'light2 (Type=SwitchItem, State=ON)'! Will retry connecting to database when error count:0 equals errReconnectThreshold:0
What I did mistake in configurations and setup. I am new to use jdbc in home automation.
Please help me how i can store item states into DB.
Thanks and Regards
Amar.
