The jeelink binding says it supports jeelinks via tcp. I assume this should be done via ser2net?
Has anyone connected a jeelink to a openwrt router? Any hints how to configure this?
If someone else tries to do this, here is how it works for me:
Install ser2net on the openwrt system. And add this to /etc/config/ser2net
config proxy
option enabled 1
option port 5002
option protocol raw
option timeout 0
option device '/dev/ttyUSB0'
option baudrate 57600
option databits 8
option parity 'none'
option stopbits 1
Then change your jeelink thing to tcp/ip and set the correct ip and port (5002 see above).
