Thanks, but still not working. I’ve used a different sd card tonight, it installs fine as before, going to http://openhab:8080/
I get ��� 3 ? in diamonds and it produces this in the log
openhab-cli showlogs
==> /var/log/openhab2/audit.log <==
Caused by: java.util.concurrent.TimeoutException: Idle timeout expired: 30000/30000 ms
at org.eclipse.jetty.io.IdleTimeout.checkIdleTimeout(IdleTimeout.java:166) ~[?:?]
at org.eclipse.jetty.io.IdleTimeout$1.run(IdleTimeout.java:50) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:?]
… 1 more
Steps to recreate, flash openhabian 1.5 from site to a 16Gb card, tonight I’m using a 32Gb card.
insert into RPI 2 B
boot and wait
after 20-30 minutes log in via console
run setup, install option component mosquitto, set password, update
visit openhab:8080/
if it loads select standard
2019-10-07 22:05:25.564 [thome.event.ExtensionEvent] - Extension ‘package-standard’ has been installed.
2019-10-07 22:05:44.046 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /start/css/bootstrap.min.css
javax.servlet.ServletException: java.io.IOException: java.util.concurrent.TimeoutException: Idle timeout expired: 30000/30000 ms
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) ~[?:?]
<…SNIP …>
2019-10-07 22:05:52.715 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2019-10-07 22:05:52.823 [thome.event.ExtensionEvent] - Extension ‘ui-homebuilder’ has been installed.
2019-10-07 22:05:52.831 [thome.event.ExtensionEvent] - Extension ‘ui-basic’ has been installed.
2019-10-07 22:05:52.838 [thome.event.ExtensionEvent] - Extension ‘ui-habpanel’ has been installed.
2019-10-07 22:05:52.843 [thome.event.ExtensionEvent] - Extension ‘ui-paper’ has been installed.
however the webpage doesn’t move on and reloading the page and I’m back to the diamonds.
maybe its up stream or am i just using a bad combination of the very latest updates to the packages.
I also put the card in a pi 3 and it was equally stuck. I’m going to revert to an earlier openhabian image and see if that works.
