Journey to JSR223 Python 3 of 9
This post is a bunch of simple little Rules which rounds out the transfer from my admin.rules file.
Send a system status alert every morning and when OH restarts
Rules DSL
rule "Reminder at 08:00 and system start"
          Time cron "0 0 8 * * ? *" or
          System started
    val numNull = gSensorStatus.members.filter[ sensor | sensor.state == NULL ].size
    if( numNull > 0) logWarn("admin", "There are " + numNull + " sensors in an unknown state")
    val offline = gSensorStatus.members.filter[ sensor | sensor.state == OFF ]
    if(offline.size == 0) return;
    val message = new StringBuilder
    message.append("The following sensors are known to be offline: ")
    offline.forEach[ sensor |
        var name = transform("MAP", "admin.map", sensor.name)
        if(name == "") name = sensor.name
        message.append(name)
        message.append(", ")
        gOfflineAlerted.members.filter[ a | a.name==sensor.name+"_Alerted" ].head.postUpdate(ON)
    message.delete(message.length-2, message.length)
    aInfo.sendCommand(message.toString)
Get the list of Items that are OFF and build a message listing those Items and alert. Set the alerted flag to ON.
Iā€™ve not touched this Rule in years and as written it could be improved some.
Python
from core.rules import rule
from core.triggers import when
from core.metadata import set_metadata, get_key_value
from personal.util import send_info
@rule("System status reminder", description="Send a message with a list of offline sensors at 08:00 and System start", tags=["admin"])
@when("Time cron 0 0 8 * * ? *")
@when("System started")
def status_reminder(event):
    status_reminder.log.info("Generating daily sensor status report")
    numNull = len(filter(lambda item: isinstance(item.state, UnDefType), ir.getItem("gSensorStatus").members))
    if numNull > 0: status_reminder.log.warning("There are {} sensors in an unknown state!".format(numNull))
    offline = filter(lambda item: item.state == OFF, ir.getItem("gSensorStatus").members)
    if len(offline) == 0:
        status_reminder.log.info("All sensors are online")
        return
    status_reminder.log.info("Building message")
    offlineMessage = "The following sensors are known to be offline: {}".format(", ".join(map(lambda sensor: "{}".format(get_key_va
lue(sensor.name, "Static", "name") or sensor.name), sorted(sensor for sensor in offline))))
    status_reminder.log.info("Updating all of the alerted flags")
    for sensor in offline: set_metadata(sensor.name, "Alert", { "alerted" : "ON"}, overwrite=False)
    status_reminder.log.info("Sending the message")
    send_info(offlineMessage, status_reminder.log)
Power Meter Status
My Zwave whole house power meter often falls offline. This little Rule converts the ONLINE/OFFLINE Thing statuses to an Online Item used by the rest of the Rules.
Rules DSL
rule "Power Meter OFFLINE"
    Thing "zwave:device:dongle:node7" changed from ONLINE to OFFLINE
    vPowerMeter_Online.sendCommand(OFF)
rule "Power Meter ONLINE"
    Thing "zwave:device:dongle:node7" changed to ONLINE
    vPowerMeter_Online.sendCommand(ON)
Python
@rule("Power Meter online status", description="Zwave has marked the power meter as offline", tags=["admin"])
@when("Thing zwave:device:dongle:node7 changed")
def pm_online(event):
    pm_online.log.info("Power meter Thing changed status {}".format(event.statusInfo.status))
    if event.statusInfo.status == ONLINE: events.sendCommand("vPowerMeter_Online", "ON")
    else: events.sendCommand("vPowerMeter_Online", "OFF")
Process Heartbeat
Rules DSL
Iā€™ve a number of devices (Sonoffs, ESPEasy, my own sensorReporter scripts) that report their uptime periodically as a heartbeat. This Rule will ping the Online Item when a heartbeat is received to reset the Expire binding and keep the device/service online.
rule "Process heartbeat"
    Member of SensorEvents received update
    sendCommand(triggeringItem.name.replace("Uptime", "Online"), "ON")
Python
@rule("Process heartbeat", description="Process an uptime heartbeat message to ping the online status of a sensor", tags=["admin"])
@when("Member of SensorEvents received update")
def heartbeat(event):
    events.sendCommand(event.itemName.replace("Uptime", "Online"), "ON")
Update Items to UNDEF when the service goes offline
These are currently three different Rules. Eventually Iā€™ll merge them into one more generic approach.
Rules DSL
rule "Hydra went offline"
    Item vHydra_SensorReporter_Online changed to OFF
    logInfo("admin", "Hydra went offline, setting relevant Items to UNDEF")
    vFrontDoor.postUpdate(UNDEF)
    vFrontDoor_Timer.postUpdate(OFF)
    vBackDoor.postUpdate(UNDEF)
    vBackDoor_Timer.postUpdate(OFF)
    vGarageDoor.postUpdate(UNDEF)
    vGarageDoor_Timer.postUpdate(OFF)
rule "Cerberos went offline"
    Item vCerberos_SensorReporter_Online changed to OFF
    logInfo("admin", "Cerberos went offline, setting relevant Items to UNDEF")
    vGarageOpener1.postUpdate(UNDEF)
    vGarageOpener1_Timer.postUpdate(OFF)
    vGarageOpener2.postUpdate(UNDEF)
    vGarageOpener2_Timer.postUpdate(OFF)
rule "Manticore sensorReporter went offline"
    Item vManticore_SensorReporter_Online changed to OFF
    logInfo("admin","Manticore went offline, setting relevant Items to UNDEF")
    vJennPhone_Manticore_Net.postUpdate(UNDEF)
    vRichPhone_Manticore_Net.postUpdate(UNDEF)
    vGJPhone1_Manticore_Net.postUpdate(UNDEF)
    vGJPhone2_Manticore_Net.postUpdate(UNDEF)
Python
# TODO: make generic
@rule("Hydra Offline", description="Sets relevant Items to UNDEF when this sensor goes offline", tags=["admin"])
@when("Item vHydra_SensorReporter_Online changed to OFF")
def hydra_offline(event):
    hydra_offline.log.warn("Hydra went offline, setting relevant Items to UNDEF")
    events.postUpdate("vFrontDoor", "UNDEF")
    events.postUpdate("vFrontDoor_Timer", "OFF")
    events.postUpdate("vBackDoor", "UNDEF")
    events.postUpdate("vBackDoor_Timer", "OFF")
    events.postUpdate("vGarageDoor", "UNDEF")
    events.postUpdate("vGarageDoor_Timer", "OFF")
@rule("Cerberos Offline", description="Sets relevant Items to UNDEF when this sensor goes offline", tags=["admin"])
@when("Item vCerberos_SensorReporter_Online changed to OFF")
def cerberos_offline(event):
    cerberos_offline.log.warn("Cerberos went offline, setting relevant Items to UNDEF")
    events.postUpdate("vGarageOpener1", "UNDEF")
    events.postUpdate("vGarageOpener1_Timer", "OFF")
    events.postUpdate("vGarageOpener2", "UNDEF")
    events.postUpdate("vGarageOpener2_Timer", "OFF")
@rule("Manticore Offline", description="Sets relevant Items to UNDEF when this sensor goes offline", tags=["admin"])
@when("Item vManticore_SensorReporter_Online changed to OFF")
def manticore_offline(event):
    manticore_offline.log.warn("Manticore went offline, setting relevant Items to UNDEF")
    events.postUpdate("vJennPhone_Manticore_Net", "UNDEF")
    events.postUpdate("vRichPhone_Manticore_Net", "UNDEF")
    events.postUpdate("vGJPhone1_Manticore_Net", "UNDEF")
    events.postUpdate("vGJPhone2_Manticore_Net", "UNDEF")
Previous: Journey to JSR223 Python 2 of 9
Next: Journey to JSR223 Python 4 of 9
EDIT: Corrections and improvements from 5iver.
Another wayā€¦
https://openhab-scripters.github.io/openhab-helper-libraries/Guides/But%20How%20Do%20I.html#stop-a-rule-if-the-triggering-item-s-state-is-null-or-undef
Use statusInfo.status for this. statusInfo can be ONLINE, but Iā€™ve never seen it go to just OFFLINE.
OK, this is a weird one.
The reporting Rule above with the cron trigger wasnā€™t working. I looked into it a bit more and I was receiving an error in events.log, of all places.
Originally the trigger was "0 0 8 * * ? *". This generated
2019-07-25 16:14:29.307 [.event.RuleStatusInfoEvent] - 0e382029-2a19-4caa-9bc9-27ed2efec62e updated: UNINITIALIZED (INVALID_RULE): Validation of rule 0e382029-2a19-4caa-9bc9-27ed2efec62e has failed! Invalid module uid: Time-cron-0 0 8 * * ?-92357e51af2911e9b576a972d4d66768. It is null or not fit to the pattern: [A-Za-z0-9_-]*
  • The Triggers docs implies that I donā€™t need the ā€œTime cronā€ part.
  • Why didnā€™t I get an error in openhab.log?
  • I understand why it appeared in events.log since it is an event.
Another known bug that Iā€™ve already fixedā€¦ I still havenā€™t pushed yet. Use ā€˜Time cron ā€¦ā€™ for now.
Should have never been in there as an option. I only included it in the code to keep the same functionality as in the original libraries.
Rich, do you mind to cross-check your ā€œJourneyā€ code for unicode compatibility ?
With Python 2/Jython ā€œnot there yetā€, they donā€™t necessarily work out of the box.
Many European OH users to naturally use non-ASCII umlauts in item names/descriptions, log strings etc to come to hit this soon I guess.
The first example here bails out on a group of sensors of mine. Might be just silly me, still learning Python and not gotten to the ground but Iā€™m guessing itā€™ll be unicode stuff to affect this somewhere.
Iā€™m not sure I know how the best way is. Iā€™m no python expert myself and about all I know about Unicode is that if you out a u before a string I think it forces it to use Unicode e.g. u"My String". @5iver, @CrazyIvan359, any ideas?
Unicode wonā€™t get only European users but any user who uses a temperature UoM.
A quick Google search may help.
https://docs.python.org/2/howto/unicode.html
That already is the first and most often hit pitfall. Iā€™d suggest to use u"" in your code by default.
The other implications are a bit more difficult, e.g. if you pass strings to functions, you eventually would need to convert them first (eventually using the unicode() constructor but as I said I have not gotten to ground myself).
Maybe ā€œstart simpleā€ and artificially create items(s) to contain UTF-8 names or descriptions and then use these in your code ? So youā€™ll notice yourself right away.
Yes and potentially more. But UoM is more of a corner case while I fear any European user of OH to embark on this ā€œjourneyā€ will hit this right away and it has the potential to quickly demotivate him (for him, Python is likely also all-new).
I donā€™t think thatā€™s the best way though. I canā€™t imagine a language as popular as python would require that. There had to be a way to say ā€œthis whole file uses Unicodeā€ or ā€œthis whole module uses Unicodeā€. I donā€™t want to change anything until I know the best way.
I thought I covered this hereā€¦
Iā€™d need some specific examples of code that is failing. The helper libraries probably donā€™t need help with unicode, since so many are using them successfully. So, any issues would be in scripts or community solutions.
At times, encode and decide need to be used too. Iā€™ve spent a bit of time working through this since your other post in order to get this documented.
I agree
Thatā€™s why Python3 changed the default! Unicode is a pain in, especially in Python2.
So donā€™t use # -*- coding: utf-8 -*- because there is some bug in Jython. Use u"string" everywhere.
Yuck but if thatā€™s how it has to beā€¦ Iā€™ve a lot of examples to edit.
Iā€™ve hit it when implementing right the example code of this thread, thatā€™s why I posted it here.
Try to apply it to an item that has umlauts in its description (2nd field in .items is what I mean by that).
Iā€™ll get back to you with more examples when Iā€™ve managed to fully understand whatā€™s going on.
There are several examples in this post :slightly_smiling_face:. Which line has the problem with unicode strings?
If I have the following:
Would a.name==sensor.name+u"_Alerted" force the whole thing to be Unicode? Or does everything really need to use format instead of string concatenation? u"{}_Alerted".format(sensor.name)? I think Iā€™ve since moved all my code to use format anyway but these early examples of mine donā€™t.
The one with format...lambda (if you have non-ASCII item names or other fields to be used in the group/item data structure, I havenā€™t fully determined the root cause yet)
So, the System Status exampleā€¦ maybe this line?
What error do you get, and did you remove the errant space?
yes
yes
I did use the line below. Problem may be elsewhere, too (Iā€™m a newbie to Python).
battery_msg = u"BatteriestƤnde unter der Meldegrenze : {}".format(", ".join(map(lambda sensor: "{}".format(get_key_value(sensor.name, "Static", "name") or sensor.name), sorted(sensor for sensor in battery_low))))
2019-12-15 17:50:00.254 [ERROR] [jsr223.jython.battery monitor       ] - Traceback (most recent call last):
  File "/etc/openhab2/automation/lib/python/core/log.py", line 51, in wrapper
    return fn(*args, **kwargs)
  File "<script>", line 27, in battery_check
  File "<script>", line 27, in <lambda>
NameError: global name 'get_key_value' is not defined
2019-12-15 17:50:00.280 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule '4a7be6ef-8eff-4746-a86d-3f84fc03c850': Fail to execute action: 1
2019-12-15 17:50:00.282 [DEBUG] [e.automation.internal.RuleEngineImpl] -
java.lang.RuntimeException: Fail to execute action: 1
        at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1197) ~[bundleFile:?]
        at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:993) [bundleFile:?]
        at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:91) [bundleFile:?]
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_222]
        at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_222]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
        at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
Caused by: org.python.core.PyException
        at org.python.core.Py.AttributeError(Py.java:207) ~[?:?]
        at org.python.core.PyObject.noAttributeError(PyObject.java:1032) ~[?:?]
        at org.python.core.PyObject.__getattr__(PyObject.java:1027) ~[?:?]
        at core.rules$py.execute$6(/etc/openhab2/automation/lib/python/core/rules.py:110) ~[?:?]
        at core.rules$py.call_function(/etc/openhab2/automation/lib/python/core/rules.py) ~[?:?]
        at org.python.core.PyTableCode.call(PyTableCode.java:171) ~[?:?]
        at org.python.core.PyBaseCode.call(PyBaseCode.java:308) ~[?:?]
        at org.python.core.PyBaseCode.call(PyBaseCode.java:199) ~[?:?]
        at org.python.core.PyFunction.__call__(PyFunction.java:482) ~[?:?]
        at org.python.core.PyMethod.instancemethod___call__(PyMethod.java:237) ~[?:?]
        at org.python.core.PyMethod.__call__(PyMethod.java:228) ~[?:?]
        at org.python.core.PyMethod.__call__(PyMethod.java:218) ~[?:?]
        at org.python.core.PyMethod.__call__(PyMethod.java:213) ~[?:?]
        at org.python.core.PyObject._jcallexc(PyObject.java:3644) ~[?:?]
        at org.python.core.PyObject._jcall(PyObject.java:3676) ~[?:?]
        at org.python.proxies.core.rules$_FunctionRule$68.execute(Unknown Source) ~[?:?]
        at org.openhab.core.automation.module.script.rulesupport.shared.simple.SimpleRuleActionHandlerDelegate.execute(SimpleRuleActionHandlerDelegate.java:34) ~[?:?]
        at org.openhab.core.automation.module.script.rulesupport.internal.delegates.SimpleActionHandlerDelegate.execute(SimpleActionHandlerDelegate.java:59) ~[?:?]
        at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1189) ~[bundleFile:?]
        ... 7 more
That looks like a missing import. Indeed, itā€™s missing the import of get_key_value from core.metadata. somehow I messed up the copy and paste of that rule, or I came back later and updated without fixing the imports.
Thatā€™s probably what happened because I have centralized getting an Itemā€™s name from metadata to a library function in my production code after I posted this but Iā€™m sure I had to come back and update some bug I found so I reverted the function call and forgot to add back the import.
Ok yes thanks for the hint, now it works. So sadly itā€™s not the example Scott is looking for.
But this was when I thought that if the name or some other string was used as a selector to access an array or some such it might fail when itā€™s not ASCII, hence my post on (non-)Unicode as a potential error source.
